SB Specialty Metals LLC
N. Brian Huegel
Postby N. Brian Huegel » Thu Mar 21, 2013 10:18 am
Here is information about a new alloy, PSF27, and production technique:
http://sb-specialty-metals.com/grades/psf27
brian
http://www.countryknives.com
Being vigilant in the world of sharp one edge at a time.
mattman
Postby mattman » Thu Mar 21, 2013 1:01 pm
I didn't see any details about the production process, other than the "Spray Forming" in the beginning... sounds like a powder process...?
Cliff Stamp
Postby Cliff Stamp » Thu Mar 21, 2013 1:08 pm
Spray forming is a technique which is similar to PM in that basically it reduces the effective ingot size and thus reduces carbide segregation and promotes a finer aus-grain. It however does not achieve the same level as PM but isn't intended to. It is intended to basically be a mid way technique between conventional ingot steels and PM, i.e., if you could not afford PM but had a bit more money than what is needed for ingot steels you could go with spray forming.
N. Brian Huegel
Postby N. Brian Huegel » Thu Mar 21, 2013 1:11 pm
brian
N. Brian Huegel
Postby N. Brian Huegel » Thu Mar 21, 2013 1:18 pm
brian
Postby sal » Thu Mar 21, 2013 3:55 pm
Thanx Brian, Cliff.
Scott Devanna sent a piece to us. We're making a test mule now. CATRA will be the first test.
Users browsing this forum: Bing [Bot], FullFlatMind, joeyviner, Joshcrutchley1, Majestic-12 [Bot], nerdlock, p_atrick, Rinzler, Wright.88 and 64 guests
