Southard's roller bearings?
gull wing
Post by gull wing »
The Brad has been out since November, surely someone has gotten a mess in the "works". How does it handle things like fruit juice, dirt, lint in there?
The Product guide says hot soapy water, rinse, dry, lube, the usual maintenance print stuff. In the real world I could see some apple juice slowing things up. Is yours easy to care for?
I ask because, I slice apples every day and juice will find it's way in the ball bearings.
Yes, it's a bit OCD. :)
SCARAMOUCHE! :bug-red-white
razorsharp
Post by razorsharp »
Mine gets full of steel dust , its fine , still fast
gull wing
Post by gull wing »
None with goop in there?
phillipsted
Post by phillipsted »
I've been wondering the same thing, Gull. Does anyone know if some pics of the bearing assembly have been posted? I'd like to see how they are configured on the inside...
TedP
sharpguitarist
Post by sharpguitarist »
Hey Ted,
I found this.
Hope that might help.
Later,
Don
KardinalSyn
Post by KardinalSyn »
Interesting. That pic looks cool. Come to think of it, I have not yet read anyone mention about BB issues on a Spydie.
sharpguitarist
Hey guys,
I think that pic might be one of Brads customs, but I would think the bearing system would be similar.
I've seen pics of the Kershaw bearing system, and it looked about the same, just a different color for the plastic containment ring.
Later,
Don
Dodge
Post by Dodge »
Edge observer has a cut away of the stop/bearing system. No pun intended.
Flash Batch request: Flat Iron Salt (CE w/ yellow FRN)
New knife request: Police 4 Salt!!!
“Don’t be so open minded that your brain falls out”
JNewell
Post by JNewell »
Edit - see next post.
I saw a YouTube video showing disassembly of a Southard and my recollection was that the bearing cage was metal rather than plastic, but I could be mistaken or remembering incorrectly. I'll try to find the video and post a link and time segment.
JNewell
Post by JNewell »
Found a different picture in this review http://www.edgeobserver.com/category/kn ... /spyderco/ Per Taz's policy on hotlinks, I'm linking to the review rather than the picture - scroll down to the composite cutaway image and the description above it for the relevant part. :spyder:
Holland
Post by Holland »
cool video, thanks for posting it
gull wing
Post by gull wing »
Nice of the edgeobserver to do that.
Shakyamuni
Post by Shakyamuni »
Here is a picture of the Spyderco Southard Flipper's bearings, which are slightly different than the custom shown above. The bearing cage sits inside a bowl-shaped washer and is supposed to spin freely inside that recess of the titanium, touching both the washer and the blade.
I took mine apart because I had one Southard that was not as smooth opening as 2 others I had handled. I discovered that the reason for it not being smooth is that the bearing cage pictured was fitting tightly into the recess of the titanium, and was not able to spin freely. On the other side, the bearing was spinning fine.
Manbug G-10, Salt I PE, Pacific Salt SE, Caly 3.5, Green Forum Native 5, Green ParaMilitary 2, Centofante 3
mattman
Post by mattman »
Thanks for the pic!
Were you able to tune it up?
Shakyamuni
mattman wrote:Thanks for the pic!
Yes, I sanded down the sides of the bearing cage and now it is freely spinning. I absolutely love this design, and I couldn't let this ruin my enjoyment :)
JFerreira515
Re:
Post by JFerreira515 »
Both of my bearings on my domino are like this! I think it comes from too much flicking! I think the bearing actually heats up the plastic causing it to expand in the housing. I might look into metal caged bearings. Does anyone know the bearing size for the domino?
toomzz
Re: Southard's roller bearings?
Post by toomzz »
wondering which steel the balls are made of....52100 ? :rolleyes:
jonnieb
Post by jonnieb »
Mine are :)
