sharpmaker
kromo
sharpmaker
Postby kromo » Wed Mar 13, 2013 5:27 pm
Hi
where i can find the right edge for spyderco models.
i have a native 5 and delica 4 and i need to know the peerfect angle to use on shapmaker.
tks for the help
ChapmanPreferred
Postby ChapmanPreferred » Wed Mar 13, 2013 7:38 pm
The edge angle is the "wider" of the two angles. There will be a greater distance from the top of one rod to the top of the other. The other angle is for thinning the edge down after you work your way by sharpening many times into thicker steel.
Work EDC List
BRP: CF Military S90V
BLP: Forum S110V Native
[SIGPIC][/SIGPIC]
View the Video/DVD at least 2 to 3 times
Postby JD Spydo » Wed Mar 13, 2013 7:51 pm
I recommend to everyone who first gets a Spyderco 204 Sharpmaker to view the video/DVD at least 2 to 3 times before attempting to use it. And do it when you can give your undivided attention.
Also the booklet that comes with the 204 Sharpmaker ( I assume the book is still included in the Sharpmaker kit)>> has a wellspring of great information and great tips on using it.
The 204 Sharpmaker of Spyderco's is truly an indispensible sharpening tool in my vast footlocker of sharpening equipment.
But it's like one of my old school teachers used to tell me >> "If Nothing Else Works, Then Try Following Directions" And that video will give you excellent insight on getting started using it.
The only critique I have on the Sharpmaker is that I wish they would make more grits available>> particularly to have one very coarse and aggressive stone for reprofiling. I also wish that they would make available some other grits as well.
But do check out the instructions and the video/DVD and you will get the hang of it quickly.
kromo
Postby kromo » Thu Mar 14, 2013 3:15 am
tks :)
but for this 2 knifes. it's the 40 or 30 angle i need to use?
chuck_roxas45
Postby chuck_roxas45 » Thu Mar 14, 2013 3:51 am
40° for both knives would work great, IMHO.
kromo
Postby kromo » Thu Mar 14, 2013 8:21 am
ok tks :)
40º.. so it will be
chuck_roxas45
Postby chuck_roxas45 » Thu Mar 14, 2013 4:59 pm
You're welcome. If you have any other questions, we'll be glad to help. :)
araneae
Postby araneae » Thu Mar 14, 2013 6:05 pm
Definitely watch the video. Sal explains what angles to use and how to use it properly.
-Nick
Just got:Rex 45 Para 3 LTWT, Harrier 2 LTWT
kromo
Postby kromo » Thu Mar 14, 2013 8:54 pm
tks to all. you are very kind.
always ready to help :)
nice to be in this great forum.
BAL
Postby BAL » Fri Mar 15, 2013 4:21 am
kromo wrote:tks to all. you are very kind.
Nice to have you around kromo. I use the 40 on most knives myself
with the Sharpmaker. It takes a little time to get a system down.
I have taken hours to get a older knife sharp and then I have only
taken a couple minutes and a few passes to touch one up.
Using the exact same motions and a bit of patience is the key to me.
anomad
Postby anomad » Fri Mar 15, 2013 8:16 am
When I was unpacking after my last move I found a Spyderco SharpMaker VHS video tape, new in wrapper! Must be a collectors item by now. But my SharpMaker is still working away.
Users browsing this forum: Bloke, GrandallK, jdw, KnOeFz, Majestic-12 [Bot], nerdlock, skeeg11 and 25 guests
