A look at the Calypso Sprint
Uke
Postby Uke » Tue Mar 12, 2013 7:42 pm
Hello all,
Well I knew absolutely nothing about the original C54 Calypso before the release of this sprint, but on seeing the new version it immediately started calling out to me. A classy 'gents' folder in the style of the Police model you say? Well I'll try some of that! :) I managed to pick one up recently and here is what I make of it so far...
Stats from Spyderco:
blade length - 3.93" (100 mm)
cutting edge - 3.60" (91 mm)
blade thickness - 0.118" (3.0 mm)
length closed - 5.10" (130 mm)
length overall - 9.03" (299 mm)
weight - 4.4 oz (125 g)
handle material - G-10
blade steel - VG-10
Straight out of the box I was struck by just how sleek and elegant the Calypso is for such a large folder. Here is the Calypso between two well known Spydies, open and closed, to give a clear idea of size...
From the top down - Paramilitary 2, Calypso and UKPK:
You can really see the family resemblance with the UKPK and the lengthy Calypso handles just as comfortably and intuitively as the rest of the Caly family. My fingers just melt into the choils as I've come to expect from this type of Spyderco design. It's a nice long handle to get to grips with as well, for anyone out there with larger mitts! It feels solid and substantial, but not too hefty in the hand...heavier than a Para2 but lighter than a Gayle Bradley. It actually handles quite delicately and precisely and I feel that this owes a lot to just how thin and slender this knife is...
The Calypso is substantially thinner than a Para2 and it is even ever so slightly thinner than the comparatively diminutive UKPK!:
...this slim profile also makes for very comfortable pocket carry! I love how thin this knife is. Speaking of pocket carry it's not the lowest riding knife, especially when carrying tip up (my preference). I've no intention of switching the clip to tip down but I've included a shot of where the knife would ride tip down in the photo below...
From left to right - Para2, Calypso (tip up), UKPK and Calypso (tip down):
As you can see above, the wire clip is still king here, although I do feel that in comparison to the Para2 this photo is a bit misleading. The Calypso feels to me more overt than the Para due to the long slim protrusion of G10 above the pocket clip, especially when carried in more angled pockets as in the photo below...
It's not a massive difference but I though it one worth mentioning as the photos make them look so similar in this regard. I love the wire pocket clips functionally, but as I mentioned in my review of the Gayle Bradley (I can't get used to calling it the 'Bradley Folder' ;) ) I find the larger 'hour glass' style clip so much more attractive. This one in particular is very nicely finished and the bug logo is even coloured to match the brown of the G10 scales.
I did think it was a trick of the light at first, but no, that bug is definately brown!:
As far as the G10 goes, I'm a big fan of the brown. Pretty classy looking and also hides my grubby paw prints :D It's a nice and grippy G10, more on the rough end of the scale than smooth.
Uke
Postby Uke » Tue Mar 12, 2013 7:43 pm
Here she is in the hand, compared again with a Paramilitary 2 for scale:
I did wonder about the practicality of such a long thin blade, but I've actually found it more useful than I had expected. I still think I prefer shorter, stouter blades for day to day tasks, but it has been a nice novelty to carry. It is a lovely slicer and the ergos give you a lot of control over that big cutting edge.
The Spydie hole is pretty small. Far smaller than a Para or Manix and smaller than that of even the UKPK:
Despite thinking this might present problems, in use I haven't found the small hole to be an issue. It is still easily accessible when wearing heavy gloves:
Would it be easier/more reliable to open with a larger hole? Well yes, but then a larger hole would make this a different knife.
No jimping whatsoever:
Now I'm not calling for jimping on the Calypso, again it would be a different knife with this addition (those sleek lines would be broken up for one thing!) and you can always reach for a Police 3 if you want jimping on a knife in this sort of category, but carrying the Calypso over the last few weeks has solidified my preference for jimping on a thumb ramp. It just gives me that extra bit of confidence in my grip and positioning. I have however been persuaded by the Gayle Bradley into not requiring a jimped lower choil :) I have toyed with the idea of adding jimping to the thumb ramp on my Calypso in order to make it that bit more useable for me (and maybe guarantee a bit more pocket time) but I can't bring myself to do it! This temporary reincarnation of the original C54 feels like a little bit of Spyderco history so I want to carry it the way it was intended! I had also wondered why a steel a bit more exotic hadn't been paired with the Brown G10 of the sprint, but when I read that the 1998 Calypso was the first Spyderco folder to use VG10, it made sense that this recent homage should also come in VG10.
I'm sure I don't need to talk about VG10 here, good steel, decent edge retention, easy to sharpen etc. etc. Strangely enough the factory edge on this was the shallowest I've ever had on a Spydie, in fact it was pretty close to 40 degrees inclusive. I used the factory edge for the first week and it was a pretty decent working edge but I wanted extra-super-slicey from a long thin folder like this so soon reprofiled to 30 degrees inclusive...
...she is now a veritable laser beam :D
The blade is perfectly centred and straight as a die. As far as the general fit and finish goes this is nice work out of Japan. The lock up is solid as a rock, the back lock securing with a nice sharp click. There is zero play side to side and just the faintest wiggle up and down when applying a fair bit of force with the hands (not noticeable in normal use). The back spacer and liners are finished so nicely that they almost look like a single piece of metal...
The omission of a Boye dent keeps the lines smooth. Functionally I can take them or leave them to be honest; don't mind if they're there, don't mind if they're not...
Uke
Postby Uke » Tue Mar 12, 2013 7:44 pm
And the flush pivot is just fantastic! I'm not a fan of the protruding 'humpy' Caly 3 pivots so I'd love to see more of this kind of thing:
I've always found that a benefit of the back lock is very reliable blade retention and the retention on the Calypso is excellent. The photo below shows the point at which the blade becomes free of tension. Any closer to the handle than this and the blade snaps securely shut:
Here is a shot inside the handle, showing the skeletonised liners helping to keep the weight down. It's all finished very smooth and clean:
The only real issue I found was with the spot where the thumb ramp meets the back lock. It isn't a completely smooth flow and this is a bit of a shame since the rest of the knife's lines are so smooth and unspoilt. It is pretty minor though and doesn't affect use, although the first example I received had the same issue but far larger. I sent that one back to be replaced as the crevice dug noticeably into the thumb.
My Calypso on the left compared with my original example on the right:
Overall I'm pretty impressed with the Calypso sprint. I don't find the size and shape the best all round combination for my regular everyday functions but it is an absolute joy to carry and use and will undoubtably continue to see lots of pocket time just down to its sheer 'loveliness' factor. Its real strength for me is managing to feel tough and reliable yet elegant and precise in the hand at the same time. It is a beautiful design and to be honest I'm pretty flabbergasted that the Calypso it isn't a regular production model for Spyderco.
A quick snap out and about:
A great food prep slicer:
Well thanks for putting up with another lengthy review! I hope someone finds it useful. If this Calypso sprint has done anything for me it has given me a big hankering for a fancy Police 3 sprint!
Cheers for now,
Uke.
gbelleh
Postby gbelleh » Tue Mar 12, 2013 8:13 pm
Thanks for the thoughtful review and excellent pictures. I agree with pretty much everything you mentioned. I'm also enjoying my Calypso very much.
:D :spyder:
Postby 1623 » Tue Mar 12, 2013 8:17 pm
Man, that was a really great review, Uke! Excellent commentary coupled with superb images made this a joy to read through.
Very well done.
-Jodi
It's not just in my head, it's in my heart.
Liquid Cobra
Postby Liquid Cobra » Tue Mar 12, 2013 8:43 pm
Now that's a review! Slow 80's clap...clap...clap. Nice work!
Most recently acquired: Paramilitary 2 Tanto, YoJUMBO, Swayback, Siren, DLC Yojimbo 2, Native Chief, Shaman S90V, Para 3 LW, Ikuchi, UKPK, Smock, SUBVERT, Amalgam, Para 3 CTS-XHP, Kapara, Paramilitary 2 M390
@liquid_cobra
Donut
Postby Donut » Tue Mar 12, 2013 9:37 pm
I think the Ulize is a fancy Police 3 sprint.
Maybe we can hope for a laminate Super Blue sprint. :)
It was an excellent review. I enjoyed it.
Thank you.
-Brian
A distinguished lurker.
Waiting on a Squeak, Pingo, and Cliptools with a Split Spring!
BigBill5953
Postby BigBill5953 » Tue Mar 12, 2013 9:40 pm
Great review! Ive been loving my Calypso since I got it. The swedge on the top of the blade is icing on the cake for me!
-Billy
Centofante 3|Brown FFG Delica 4|Persistence|Sharpmaker & UF rods|SS Kiwi|Manbug SE|Blue UKPK SE Leaf|Calypso Jr. FRN|Blue Dodo SE|Centofante 3|Grasshopper|Tan Ladybug Salt|Rookie Sprint|
bammann45 wrote:In Los Angeles we have roaming packs of carnivorous tortoises. I am glad we finally have a folder that can punch through their shells.
Holland
Postby Holland » Tue Mar 12, 2013 10:59 pm
excellent comparison shots and write up!
Junction | Gayle Bradley 1 & 2 | Mantra 1 | Chaparral 1 | Dragonfly 2
Stony
Postby Stony » Tue Mar 12, 2013 11:29 pm
Now that was a great write up. Thanks for taking the time.
c.joe
Postby c.joe » Wed Mar 13, 2013 1:20 am
Great review and pictures! Thanks for taking the time to make me poorer.
Postby kennethsime » Wed Mar 13, 2013 1:30 am
Very, very nice review. Excellent pictures.
That said, who's up for an updated Calypso model with jimping in all the right places and a boye dent? :-p
Lost to the Ages: C90GRE Stretch 1 ZDP-189 British Racing Green | C28GRE2 Dragonfly 2 ZDP-189 British Racing Green
C12BK2W Matriarch 2 VG-10 Emerson Open | C81G2 Para Military 2 S30V
Currently Rotating: C81GPRGR2 Para Military 2 K390 Ranger Green | C223GPRGR Para 3 K390 Ranger Green
C90FPIV2 Stretch 2 Straight Spine, VG-10 Rit Dye'd Dark Apple Green | C223GP Para 3 S30V Green Canvas Micarta
C41BORE5 Native 5 Lightweight REX 45 Burnt Orange | C223BORE Para 3 Lightweight REX 45 Burnt Orange
C101GY2 Manix 2 Lightweight Maxamet Gray | C28GFG Dragonfly VG-10 Foliage Green
MT27 Mule Team 27 Micro-Melt PD#1 Ranger Green | C36GPGR Military 204p Dark Green
mikerestivo
Postby mikerestivo » Wed Mar 13, 2013 8:01 am
That was a superb photo review. Thank you for taking the time to post it.
I'm already fairly smitten with my Calypso sprint and it has become my go-to knife since I've had it.
xceptnl
Postby xceptnl » Wed Mar 13, 2013 8:13 am
kennethsime wrote:Very, very nice review. Excellent pictures.
I have held the new Calypso and I feel it is perfect just as is. I don't have the funds for it right now, but it is a terrific reincarnation. As BigBill said, the blade spine is the icing for me!
*Landon*
bh49
Postby bh49 » Wed Mar 13, 2013 10:43 am
Very nice review and pictures.
Thank you.
I like the sprint more than original. I used to have a matching set of PE and SE Calypsos. Traded one of them and sold another. I like black polished micarta and the blade shape. I didn't like tip down carry, no liners and worped blades. PE was much worse than SE. Brown G10 is OK for me on this knife. For some reason on some knives I like brown G10 and on some I don't. Calypso belongs to the first group.
Uke
Postby Uke » Wed Mar 13, 2013 11:02 am
Cheers guys.
Donut wrote:I think the Ulize is a fancy Police 3 sprint.
Thank you.
I loved the look of the Ulize when I first saw it, but for me I need a forward choil that lets me really choke up on the blade (as on a Police 3/Calypso etc.) Police 3 sprint or Ulize with a choil...either would do for me :)
SpyderScout
Postby SpyderScout » Wed Mar 13, 2013 2:19 pm
Great review of one of my favourite Spyderco knives.
Super pics as well.
[SIGPIC][/SIGPIC]
C-54: A Permanent Top 10 Spyder in my list
Postby JD Spydo » Wed Mar 13, 2013 7:39 pm
For some of you all who have known me for the past 8 years or so since I joined this great Forum in Sept of 2004 I've always maintained a constant list that I revise from time to time and I even do threads on it. I like to call it JD's Top 10 Spyders of all time. I did the thread about 3 months ago if anyone is interested in checking it out.
Well anyway I'll just say that the original C-54 Calypso model has been in my JD's Top 10 list for quite a few years now. Back in the late 90s when I was just sort of getting my feet wet with Spyderco's great folders I had a dealer here locally show me the C-54 Calypso in 1998 I think it was at a local Gun Show here in KC, MO USA.
And since then it's been one of my favorite Spyderco in house designs of all time. And considering the awesome collaborations that they have blessed us with over the years I think that says a lot. I love many of the collaborations and I'm currently carrying my C-60 Massad Ayoob model. But at this present time the C-54 Calypso is truly one of my all time favorites from the standpoint of Looks, Function and overall Design. And don't lose sight of the fact that the C-54 is one of Spyderco's IN HOUSE designs>>> and one of their best I might add.
And don't overlook it's fixed blade cousins the Temperance 1 and Temperance 2 models which were spawned from this fabulous design.
LONG LIVE THE C-54 model !!!! :cool: Truly an all time top 10 great.
The C-54 is truly a "Permanent Top 10 Favorite" of mine and this new Sprint of this great model shows all of us just how great it is. I would love to see them do another Sprint Run of the C-54 in one of the supersteels like ZDP-189 or some steel like it. This folder is truly the Cat's Meow :cool:
JLS
Postby JLS » Wed Mar 13, 2013 9:17 pm
Excellent review! I really enjoyed reading it and I agree with you that it's a fantastic knife; I've certainly enjoyed mine. It's a very elegant and refined 4" knife...and that's not easy to do.
I do miss the extreme light weight of the original, but I'll take the consistency in opening on the new with the liners and the options for clip positioning even if I do prefer the tip down RH carry of the original.
42 Spyderco fixed blades and counting...
D1omedes
Postby D1omedes » Wed Mar 13, 2013 9:22 pm
Very nice review, Uke. ;)
I am a die hard Caly fan but the 3.5 is as large as I will go. For my tastes, once a blade nears 4 inches I think it might be time for a fixed blade. Still, it is great to see Spyderco bring back a classic with some fine improvements. I wish that flat pivot would be applied to the current Caly 3.5's but perhaps that is something that can happen in the future.
Great to see someone actually USE one of their :spyder: 's and offer real insight. Once again, great review. :D
Users browsing this forum: Bill1170, Bing [Bot], Enactive, Google [Bot], jdw, jpm2, koenigsegg, T2C, Theldraskien and 32 guests
