I've used my B75P Mule for a few weeks now and took off the Halpern "temporary" handles and was going to start on some green canvas micarta scales. When checking passage of drills due to the burrs left from laser cutting, I noticed that the holes were HUGE! The small holes that are a nominal 3/16" and that normally measure about .192"-.194" were .198"-.199" and the nominal 3/8" holes that normally measure .378"-.380" were .402"-.405". I will make myself some pins that fit snug, but I'm left to wonder if this is a rolling change that we'll see in the future or if this is truly an anomaly.
I did check sizes against the naked Cruwear and 9Cr18Mo Mules that I have on hand and they were just like all of the others.
Anyone else run into this issue when putting a handle on their B75P Mules?
MT15 CTS-B75P handle hole sizes are bigger than previous
42 Spyderco fixed blades and counting...
Many of my mules, the holes are just snug enough that I can't always fit the fastener hardware through them (using Halpern Titanium scales and hardware). Initially I spent a lot of effort trying to fit a rat-tail file in, or use a small cone-shaped stone on my drill to enlarge them, but found that just using a bit of sandpaper, rolled into a tube shape small enough to fit into the hole, worked very quickly without much effort, I guess it was just a bit of snags left over from the laser cutting.
Didn't really have to remove much material, just smooth it out. I don't remember the exact grit I used, I think maybe 400, wet-dry sandpaper, works great.
