Gayle Bradley only says Taiwan?
Hey guys,
I'd recently seen somewhere about the Gayle Bradley being improved with drilled liners to cut weight, etc. but didn't know when these changes happened. I've seen a GB with only Taiwan on the blade instead of Taichung Taiwan, and didn't know if this indicated an earlier or later model.
Can anyone provide some info?
Chris
Chris
My second run GB has the skeletonized liners and Taichung on the blade base. I believe those two things are synonymous, but not 100% positive. I think that the inclusion of cities to distinguish manufacturers both in Japan and Taiwan happened in the years between the two production lots. That's my impression, anyway.
:spyder:: Advocate, Slysz Bowie Ti, Southard Black Blade, Stretch Carbon Fiber w/ZDP-189, Fluted Ti Native5, Terzuola Starmate, Terzuola SLIPIT, Leaf Storm, Gayle Bradley, Roadie, Chaparral CF, Chaparral Ti Stealth, Des Horn, Stretch FRN (Blue) ZDP-189, Centofante Memory, Military Black Blade CE, Delica4 FRN CE, Endura4 FRN Black Blade CE, Assist Orange FRN, Manbug ZDP-189, Ladybug 3 FRN SE, Delica4 Blue NLEOMF, Moran Drop Point BB, et al. :spyder: Spydie Fanatic #179 :spyder:
My 2nd generation has the GB Weatherford, Texas logo, yes.
IIRC the first 200 or so didn't have Gayle's logo. The rest of the run did had his logo with solid liners.
I would assume that they probably wouldn't normally make a change in the middle of a run (other then for something like missing the makers mark) and so I would think that the addition of Taichung was probably added on the second run, which also has the drilled liners. Just my thought...could be totally wrong.
On the hunt for...
- chuck_roxas45
And the first run with the reportedly higher Rc....
- Wildernest Survivor
- jackknifeh
I think the Rc now is around 64 and I have one of the newer ones. Is that the Rc now? What was it when it was higher? Were there problems like chipping when it was higher? If not, why lower it? Or was it an accident by turning the stove up too high? :)chuck_roxas45 wrote:And the first run with the reportedly higher Rc....
Jack
- chuck_roxas45
I think the ones on the regular(present) GB is around 62Rc. I really don't know if the first run was dialed in at around 64Rc. That's just talk around the forums which might or might not be based on facts. I think the only Spyderco steel at 64Rc now is ZDP.
Oh, my word, Blake. We just got back from the Outer Banks and I read the LOTR series while I was there. Never had before. Read the Hobbit back in the 70s but never LOTR. Great series. Even d/l'd the Simerilian to read next.Blerv wrote:They also glow blue when trolls are near. Save me Aragorn! :)
I think Sam would totally carry a GB! OTOH, I want Glamdring
Ken
(by the way, it was Orcs.... Did it glow with Trolls?)
玉鋼
I'm not sure, lol! I vaguely recall that little hobbit sword glowing blue prior to that HUGE thing busting through. Was that a troll?kbuzbee wrote:Oh, my word, Blake. We just got back from the Outer Banks and I read the LOTR series while I was there. Never had before. Read the Hobbit back in the 70s but never LOTR. Great series. Even d/l'd the Simerilian to read next.
Ken
Regardless Sam was totally a GB carrier. :D
Okay, got it.Blerv wrote:I'm not sure, lol! I vaguely recall that little hobbit sword glowing blue prior to that HUGE thing busting through. Was that a troll?
Same applied to Glamdring and String (Bilbo's/Frodo's sword)They buried Thorin deep beneath the Mountain... Upon his tomb the Elvenking then laid Orcrist, the elvish sword that had been taken from Thorin in captivity. It is said in songs that it gleamed ever in the dark if foes approached, and the fortress of the dwarves could not be taken by surprise.
But I think in the scene you're thinking of it was an Orc.
Ken
(we now return you to your regularly scheduled programming)
玉鋼
chuck_roxas45 wrote:I think the ones on the regular(present) GB is around 62Rc. I really don't know if the first run was dialed in at around 64Rc. That's just talk around the forums which might or might not be based on facts. I think the only Spyderco steel at 64Rc now is ZDP.
Both Sal and Mr. Bradley posted shortly after the GB first hit the streets that they had separately tested these and gotten results in the 64-65Rc range.
My GB was ordered within the day they were available at dealers, has solid liners, is stamped Taiwan, and has the Bradley logo.
It glows in the dark only when very sharp, and is in the presence of evil :D I keep it very sharp :)
Charlie
