Update on the Stretch?
2 questions: Are they still working on that flat back version? and did they ever fix the warped blade issues found in this thread?
http://www.spyderco.com/forums/showthread.php?t=40499
Thanks. Just curious
- The Deacon
AFAIK, Sal has neither ruled out or committed to offering a flat spined Stretch, but I believe there's still a good chance we'll see one, either as a Sprint or Limited Production piece. I suspect the "problem" was, at best, an isolated incident. If not, it was probably something confined to a few specimens of the CF version, which is no longer in production. Between the ones I still own, and the ones I've given as gifts, I've had my hands on at least a half dozen of the FRN ones, and none have had off centered blades.
Mine is centered and not warped too. ZDP-189/Blue FRN.
I have yet to see anything of a notice or recall on Stretch so as mentioned it seems an isolated. In fact, and I say this trying to not sound like a seething fanboi but I don't recall having anyone confirm their model was "warped" via Spyderco W&R. They have a tenancy to replace and fix situations and people usually share their experiences so perhaps I'm wrong but never saw it.
If anyone has sent their knife in, it was confirmed warped, and action was taken, please let us know.
- JacksonKnives
- jabba359
The problem with the ZDP Mule was that it was brittle and cracked. IIRC, official word was that it wasn't a heat treat issue but something about the chemical makeup of that particular batch of steel or something along those lines...JacksonKnives wrote:Seems to me the warpage problems were with the mule, but my memory is fuzzy on that one, too.
There were problems with the Caly Jr. blades warping. If memory serves me correctly, that was one of the issues that led to it being discontinued.
- kennethsime
- jackknifeh
One of the things about the Stretch that makes it great is the curved spine IMO. We have different models from Spyderco giving us many choices. We can't get everything though. I like the Stretch handle and the blade spine as is. Someone else may want the Stretch handle and a straight spine. I believe Spyderco has enough straight spines. One thing I like about the GB is the "not-straight" spine. Gives it an obvious different look and sometimes a difference in performance. Different performance would be very limited but as an example the Stretch was mentioned a while back to be a good knife to cut around the anus of a deer when dressing it. Kind of a gross example to some but a "I need that feature" example to others. But I can't see where a straight spine on the Stretch would make it better. Others may have reasons it would be better. I also wonder what Spyderco would have to do to get the straight spine for a Stretch. My vote is leave the Stretch as is.
Jack
Jack
Add a deep pocket clip, and I would completely agree with you.Donut wrote:I don't know why anyone would want to change a perfect knife.
The important thing was that I had an onion tied to my belt, which was the style at the time. You couldn't get white onions, because of the war. The only thing you could get was those big yellow ones...
- jackknifeh
I'm finding out that pocket clips can be made to a user's specs with little cost (or effort) and it won't void the warranty as long as you don't do more that what would normally be done in changing the location of the clip. I like this. I put a wire clip on my GB but I had to carve grooves in the CF. I didn't have to take the knife apart so I wonder if that would void the warranty? Doesn't matter on mine because I've disassembled it 137 times. Please don't tell Spyderco. sssshhhhhh :)Onionman wrote:Add a deep pocket clip, and I would completely agree with you.
Jack
Jack
I have seen the threads with the custom deep pocket clips and saw your GB with the wire clip (really nice by the way). While I could do that if I really needed it, the custom clips look custom and just don't look like they belong on a Spyderco. I guess what I am saying is that I want a bug on my clip! Seeing how other companies made deep pocket clips that screw on the side of the handle, how hard would it be for Spyderco to fashion a deep pocket clip sold separately. With the support I have seen for something like this in the forum, this would be a great seller.jackknifeh wrote:I'm finding out that pocket clips can be made to a user's specs with little cost (or effort) and it won't void the warranty as long as you don't do more that what would normally be done in changing the location of the clip. I like this. I put a wire clip on my GB but I had to carve grooves in the CF. I didn't have to take the knife apart so I wonder if that would void the warranty? Doesn't matter on mine because I've disassembled it 137 times. Please don't tell Spyderco. sssshhhhhh :)
- phillipsted
STR made me a nice thin hourglass shaped deep-ride pocket clip for my FRN stretch. We worked to get it just right so it sits down deep in the pocket yet the clip rests against the smooth Spyderco patch on the FRN so it doesn't tear up your pants pocket on the way out. Great mod.Onionman wrote:I have seen the threads with the custom deep pocket clips and saw your GB with the wire clip (really nice by the way). While I could do that if I really needed it, the custom clips look custom and just don't look like they belong on a Spyderco. I guess what I am saying is that I want a bug on my clip! Seeing how other companies made deep pocket clips that screw on the side of the handle, how hard would it be for Spyderco to fashion a deep pocket clip sold separately. With the support I have seen for something like this in the forum, this would be a great seller.
TedP
