If you could only have one spyderco....
Lately, I've done an incredibly massive amount of research on all the models Spyderco has to offer, and I can't help but like most of them. I wanted to ask the connoisseurs if you could only have one perfectly functioning Spyderco with you for the rest of your life, what model would it be, what steel would the blade be, and what material would the handle be made out of?
- jackknifeh
The first knife I owned that I considered my end all be all knife was the Sage 1. It has everything I want in a pocket knife. Size, good blade steel, VERY comfortable to use, sturdy, very attractive and classy enough for any situation. Finally, it's easy to disassemble for cleaning if necessary.
The other two that could be absolute favorites except for one thing, size. The Chaparral is everything the Sage 1 is but just a little too small for the only EDC knife I'd want to own. The other is the Gayle Bradley which is a little too large for my only EDC knife. If I had to put them in order 1) Sage1 2) Gayle Bradley 3) Chaparral.
Click below to see my favorite 3 (plus a Manix2)
[ATTACH=CONFIG]20228[/ATTACH]
Then I got the Sage 4. It has all the attributes of the Sage 1 (it is a Sage after all) with the addition of the sturdier, stronger feel of the Gayle Bradley. Some will consider it a little heavy but I don't mind. In fact if I were to have to pick a favorite weight, light or heavy, I'd rather have the heavier feel than a very light feel. Has nothing to do with performance, just a personal preferance.
Click below to see my Sage 4
[ATTACH=CONFIG]20227[/ATTACH]
So, for me, my desires and needs, the Sage 4 is my favorite knife. My favorites now are the same as before except the Sage 4 takes the number one spot and everything else moves down one.
For me the 4 knives creates a set of really great knives that suite all of my desires in an EDC knife. Now, add the Jester and then even the "little knife" needs are met. I also have a FRN Manbug that I really like and may get the G-10 Manbug one day.
Below is my Jester (with EDC light)
[ATTACH=CONFIG]20226[/ATTACH]
I plan of getting the Chaparral Stealth when possible. I'll have to wait to see if it fits in the above group and where.
I don't like the way to insert pictures. I'm sure I just don't know the slickest, easiest way to do it.
Jack
Jack
- jackknifeh
Below is a copy of my post in the thread "Favorite Spyderco". First time I've seen two "favorite knife" threads at the same time. :)
Jack
PS edit: I forgot, welcome to the forum. If you are looking to purchase a "favorite" without buying 30-50 knives to find your favorite my "set" is the result of doing just that.
Jack
- chuck_roxas45
Luckily we all can haz more than one. :D
- The Deacon
IMHO, that's not the way it works. More of a "horses for courses" as our British friends like to say. A burgundy Micarta Jester is my single most carried folder. The one I use has been on my keyring for nearly nine years. However, in all that time, it has seen relatively little use. As much as I would not want to be without it, I would not want to rely on it as my only knife.
For the past seven years I've carried one version or another of the Stretch as my primary folder far more often than any model. Sal says he designed the Stretch for himself. If that's the case, then he and I must have
almost identical hands, since it fits me like it was custom made for me. But even with it, there are times thin is best and I carry the CF version, times when thick is best and I have to choose between either my STR customized Lignum Vitae or an FRN Stretch, and times when something in between is best or I want something really special in my pocket and I carry the bolstered cocobolo one Sal gave me. Then there are days when the law decides for me, and I have to leave all of them at home because they're a half inch over the legal limit where I'll be going.
When I go "downtown" here, I carry a Chaparral as my "large" folder. I consider it a major stroke of luck for me that the Chaparral came into being shortly before I moved here. It's a fantastic combination of ergonmics, good looks, and built quality and my my choice "best in class" among Spyderco's three inch blades.
Then there's the Kiwi. For me, the Kiwis made in Japan by Moki take the concept of functional jewelery to its heights. It's an excellent little knife, and would probably suffice as my only knife nine days out of ten. during its production life it was also the perfect platform for customization. Elegant looking, outstanding fit and finish, with easily replaceable scales. I haven't been without one in my watch pocket for nine years. I have more than an obscene number of them, and yet still am saddened by the thought that there will be no more.
Did you force a patina on the Caly 3.5? Your handle looks lighter (cleaner) than mine and the blade darker.kbuzbee wrote:Same answer I've provided recently... One of these two:
But favore is slowly shifting from the Bradley to the Caly SB. Tough call though. Glad it's only theoretical.
Ken
The Caly 3.5 SB has been my almost daily companion over the last 6 months and is definitely one of my favorites.
- SpyderNut
I totally agree with you on the Burgundy Jester, Paul. I have always loved mine too. If memory serves correct, I think I spent about $40.00 for it back "in the day" when they were new. :)The Deacon wrote:...A burgundy Micarta Jester is my single most carried folder. The one I use has been on my keyring for nearly nine years...
However, if I could only choose one Spyderco (as insanely difficult as that would be), I would still choose my Starmate 60/40 with CPM-440V steel and G-10 handle. That knife can't be beat. :D
:spyder: -Michael
- Wildernest Survivor
If I could only carry one Spyderco, it would be my S90V Para2. From the blade steel, to the carbon fiber scales, to the compression lock, and finally to the pocket-friendly blade length, this is perhaps the perfect EDC folder. Even if this knife was not available, I would still choose a Para2. :D
"Next time there's a revolution - wake up earlier!"
[SIGPIC][/SIGPIC] Vince Aut Morire
No Question about it>> The C-44 Dyad
If I could truly have just one Spyder from here on out the model I would undoubtedly pick would be my all time favorite C-44 big Dyad model. Because with that blade you have the best of both Spyder Worlds and that is a great sheepsfoot Spyderedged blade along with a super streamlined, plain edged clip point blade.
For the life of me I can't understand why we haven't seen that model come back as a Sprint Run if nothing else. And I won't rest one second until we see that dream come to pass. If we could get the C-44 Dyad back in either VG-10 or better yet one of the Super-Steels I would probably buy at least 3 of them.
The only changes I would like to see with that model would be some type of a lanyard hole and a G-10 handle similar to the one on my C-60 Ayoob Sprint model. That's my #1 pick
- The Mastiff
I truly can't decide between my
1) CPM M4 ti Military sprint
2) Caly 3.5 Super Blue
3) CF Stretch ZDP
4) S90V P2
5) VG10 FFG Endura
6) O-1 Bushcrafter
7) Mastiffwear mule
I really, honestly can't come up with just 1. I did good getting the list down to 19.
joe
3) CF Stretch ZDP
4) S90V P2
5) VG10 FFG Endura
6) O-1 Bushcrafter
7) Mastiffwear mule
joe
You're lucky. I got bitten after this sprint endedWildernest Survivor wrote:If I could only carry one Spyderco, it would be my S90V Para2. From the blade steel, to the carbon fiber scales, to the compression lock, and finally to the pocket-friendly blade length, this is perhaps the perfect EDC folder. Even if this knife was not available, I would still choose a Para2. :D
