Do you think the lock for the Paramilitary should be swapped?
I typically use my Para with my right hand. I have two options for unlocking it, either:
A. Pinch the lock with my thumb and forefinger. (The side the lock is on doesn't matter for this option.)
B. Take my thumb, shift it to the opposite side of the knife, push on the release, then bring my thumb back to the side it was on and press to flip the knife over to close it.
Wouldn't option B be a lot easier if I didn't have to reach over the knife to get to the release, then back to the original side to flip it over so I can close the blade?
-Brian
A distinguished lurker.
- michaelm466
I can't really picture how you're closing it, but I just pinch the tab with my forefinger and the opposite scale with my thumb and either let the blade fall close or give it a little flick to close it, I can open it the same way or use the spyderhole.
Edit:
I tried flipping it upside down and using my thumb for the tab instead, its still pretty easy, but IMO a little more awkward than with forefinger, which is how it would be if they put it on the other side.
Edit:
I've got mine loose enough that the blade drops at least halfway closed when I release the lock; I just have to remember to get my fingers out of the way. If I want to have more control for a RH closing, though, I hold it upside down, press the lock tab in with my middle finger, support the handle on the other side with the side of my thumb, and use my index finger to push the blade closed. Same thing works for LH, but you're pressing the tab with the thumb and holding the other side of the handle with the side of the middle finger.
I will say that I'm actually left-handed, but I don't know that it matters as I usually just let the blade drop closed after pinching between my thumb and other fingers - which as you pointed out is ambidextrous anyway.
So... I vote keep it.
Yea but it would be harder to pinch the lock with your index finger (and flick) which is a way many close the compression lock.
The Gunting was the one example of a left-side Compression lock and being that it was the only one I have to think there was a reason. My brother had a Gunting actually and didn't buy any compression locks for years because it pinched him a couple times really bad.
- jackknifeh
- computernut
We can essentially test what you're suggesting by operating the lock with our left hand. I'm fairly dexterous with my left hand and for me, option B is considerably more difficult left handed. I think it's because I end up gripping so much less of the knife.
So I voted no, no way, not even a little bit. I love the lock as is. However, I'm not against a left handed variation.
:spyder: Kiwi 4, Jester, Ladybug, Southard, Junior, Southfork, Chaparral, SpyderSaw, CF S90V PM2, Dfly G-10, PM1 :spyder:
webmaster | sharpthings.net
I voted NO, but I'm left-handed. :p With the lock as-is (on my Superleaf, as well), my method of closure couldn't be easier. I move my forefinger to the Spydie hole, press the lock against the scale with my thumb, then work the blade home with my forefinger.
I tried to type this out but it didn't make sense so i took pics. Basically, don't just pinch and close with two fingers, use your whole hand.
Don't do this:
Doing this ^^^ you only have two fingers on the knife, and you have to exert even more pressure on the lock because half the effort is from holding the knife.
Do this:
Doing this ^^^ you have 4 other fingers holding the knife, allowing your index finger to move freely. This is much easier.
Don't do this:
Do this:
+1computernut wrote:I thought it was backwards at first but I find it works well the way it is because you get your thumb on the G10 while your index finger pinches in the tab. If you try it with your left hand and pinch with your thumb you don't have as secure a grip on the handle with your index finger.
ABSOLUTELY NOT.
The only thing I would change, would be to make the cutout in the g10 a little bigger to get ahold of easier.
Caden's :spyder:'s-g10 dragonfly, digicamo para2,bug,honeybee,sharpmaker.
Newest :spyder: manix 2 lightweight.
:spyder: top wishlist: junior,D4,E4,,h1 D'fly salt,h1 ladybug salt,g10 manbug,caly3•3.5,all sprint para2's
Have to have= brad southard flipper, gayle bradley:spyder:
"combat knife is actually 10% weapon and 90% tool".~ Al Mar
- chuck_roxas45
I humbly agree. :DPopsickle wrote:Lock is perfect how it is
The only problem with that is you'll start to expose the bottom point of the choil on the blade. I don't think it would really improve access since you'd just start pressing on the blade itself if you went down any further.C.L.L 97 wrote:ABSOLUTELY NOT.
