Plus 1.Pinetreebbs wrote:WD-40 does a great job on tape adhesive for me.
Oh, good point, WD-40 not good for food prep. That would also apply to Goo Gone and Opps! The later can even get sharpie marker off plastic.chuck_roxas45 wrote:Plus 1.
But you need detergent to wash off the WD-40 residue in case you use your knife for food.
Yep. I'm rarely out where i just have WD40 with me. Most of the time you can wipe it off with your fingers for the most part.Leatherneck wrote:Spit and blue jeans.
I agree completely with the rubbing alcohol.. The toluene is Nasty stuff, though..seriously.. Use gloves. don't breath it... It's similar to benzene in that it's a bio-accumulent. In other words, if you got gasoline on you when you 5yrs old, the benzene from that gas is still in you..somewhere.. Toluene is the same way.. And, like benzene, it's a carcinogen.JD Spydo wrote:Go to your local Walgreens, CVS or whatever drug store chain you have in your neck of the woods and get some Isopropyl Alcohol ( Rubbing Alcohol). The reason I suggest to go to one of the drug store chains or just to a drug store to get the Isopropyl Alcohol is that you can get it in different strengths.
I use the 91% Isopropyl Alcohol for most of my clean up needs. Believe it or not it is a great all purpose cleaning solvent that is relatively safe to use even in indoor environments. Whether it's tape glue from scotch tape or any type of duct tape, fiberglass tape they all have a very similar adhesive and Isopropyl Rubbing Alcohol with cut through just about all of them I've cleaned up.
Also 91% Isopropyl Alcohol is great for prepping items to be glued or painted as well.
Now if you've got an adhesive that the alcohol won't cut then you need to move up to acetone or Toulene>> or even laquer thinner will cut most glues and adhesives.
Also fingernail polish remover is a remarkably strong solvent as well.
But the really nice thing about Isopropyl Alcohol is that it doesn't leave any residue to speak of and it really cleans neatly
-F1 wrote:Wire brush and/or 80-grit sandpaper.
The "magic eraser" things (regardless of brand) are abrasive; just an FYI. No idea what effect it would have on blade steel but it is basically fine sandpaper.
I'm assuming that your first comment was laced with sarcasm, otherwise, perplexing comments F1; care to elaborate?-F1 wrote:The "magic eraser" things (regardless of brand) are abrasive; just an FYI. No idea what effect it would have on blade steel but it is basically fine sandpaper.
Users browsing this forum: AHarbuck, dlopaticki, Google [Bot], sabb8pro2, TenGrainBread and 56 guests
