Belt loop carry?
Belt loop carry?
How many of you carry a spydie clipped at the top of your pants waistband and through your belt loop on the front of your pants? I am in a dress suit and tie profession so I am unable to do the traditional pocket clip carry( wouldn't look good)
EDIT: I found my SS Endura is slim enough for comfortable carry this way.
Pics to clarify how I carry it:
View from outside
View from inside
View of top looking down
View from outside
View from inside
-Ryan
-Techno, cruwear Mule, Dragonfly 2 FRN, Assist, Endura FRN ATS-55 SE, Endura SS aus-6 PE, Persistence(Wife's)
-Wicked Edge
-Wicked Edge
Sounds like a deep carry clip would be helpful. The CF Caly ZDP 189 would be my suggestion. Thin and classy.
I think that every suit I owned had a coin pocket inside the RF pants pocket to keep change from bulging the bottom of the pocket. That might be a good location for a knife.
And of course suit coats have pockets for cell phone, business card case, etc. which might be suitable. I hardly wore my suit coat in the office so my knife was in the RF change pocket of my pants.
the chaparral may suit the conditions. very thin & light... though you did say "good size" so it might be a bit small. centofante3 would also be a good choice & it's a bit larger.
i carry like this when i wear these cargo pants that have really wide belt loops...normal belt loops on jeans are too narrow to clip on imo.
:spyder: australian spyderco fan :spyder:
Just the clip goes on the outside of the pants and slides in the belt loop. The knife goes inside my waistband. Hope that makes sense.Blerv wrote:Just to clarify, not "in waistband" as the knife rests between belt and outside of pants?
Something THIN. A Cricket or Balance would prob be my choice. Stainless knives are the thinnest usually.
As for the native---- it is a little wide for my liking (uncomfortable) and being SS it is heavy. I am not a thin guy so a thicker blade spydie like a dragonfly would "cut" into my stomach when I sit down.....
-Ryan
-Wicked Edge
-Wicked Edge
By good size, I didn't mean leave size. I just meant a comfortable size. I should have clarified :) . I would like to keep the blade close to 3" or less if possible.dem0n1k wrote:the chaparral may suit the conditions. very thin & light... though you did say "good size" so it might be a bit small. centofante3 would also be a good choice & it's a bit larger.
-Ryan
-Wicked Edge
-Wicked Edge
What about the newer flat grind Delica? I would like to get something non SS to keep the weight down. BTW, thanks for the tip on the terminology :) .Blerv wrote:Ah gotcha! Yea more or less people call that IWC or in waistband carry.
There are a couple out there you wouldn't realize are on you. Mostly the SS ones mentioned. The Spin is another discontinued but would be a great office carry like that.
-Ryan
-Wicked Edge
-Wicked Edge
- Minibear453
To plug the CF Caly 3 again: same length blade as the Sage 1 but smaller handle. Plus the Sage 1 doesn't have a deep carry clip.rg02 wrote:I was actually thinking of one of those as well. I am just not sure how wide the handle is on those...... What is a good price on a sage CF?
After just dropping some coin on the Para mil 2, I really like the price point on the flat grind Delica much better than the $90+ for the chaparral..... Is the Delica that much bigger?Blerv wrote:The main problem is width for comfort. I hear some do well with Delica's. I'd rather go Rookie or Chaparall in that size though.
Just depends on what your comfortable with. You can prob get dimensions and try to emulate it.
-Ryan
-Wicked Edge
-Wicked Edge
- phillipsted
- The Deacon
If I'm visualizing this correctly, it seems that you're carrying the knife in a semi-horizontal position. If that's the case, then a narrow (top to bottom) knife would be best and you may want to look for something like a Centofante 3 or Des Horn.
