Military 2 ???
Military 2 ???
What do you think about the idea of Military2?
I mean when they use the same principle of CQI as with the Paramilitary,that could only help.Just look how this small improvments help to made the Para2 one of the best knives ever made.When they improve the handle and the choil ergonomy,use the new bushing pivot system,put a four way pocket clip,larger screws, larger lanyard hole and maybe a new lock system (Compression,Ball Bearing or Bolt Action lock) that must be a homerun.I think the change of the locking system will causes the most controversy.I don´t like liner lock and frame lock,because I simply do not like the "feel of being cut each time I close the blade" :mad: and thats why I suggest to change the lock.Let me know what do you think about it.
I'm open to a Military2. I trust Sal and company will make changes that improve on an already outstanding design. Still, I suspect you are right when you suggest that many will not like the changes, but this is probably always the case. I'm looking forward to a Military2, especially if it has 4-way options for mounting the clip.
It has been mentioned that the Military 2 is set to use the Stop Lock, which so far is new to everyone.
What I think about it is that you are doing something wrong!Igi964 wrote:I don´t like liner lock and frame lock,because I simply do not like the "feel of being cut each time I close the blade" :mad: and thats why I suggest to change the lock.Let me know what do you think about it.
-Brian
A distinguished lurker.
- JacksonKnives
I pretty much agree. IMO, the Military 1 is a much better knife than the Paramilitary 1 was. The Para 1 is nice, but had plenty of room for ergonomic improvements and design refinements. The Military could use a 4-way clip, and maybe some beefing up of the screws, etc. But, it's pretty darn great as it is.OverkiLL wrote:4-way clip is all it really needs!
Agreed, it doesnt need much. The screws and the lanyard hole need to be bigger. Dont change anything to the ergonomics, its already awesome. If they do it better be subtle changes. The liner lock is great. Its simple and strong.gbelleh wrote:I pretty much agree. IMO, the Military 1 is a much better knife than the Paramilitary 1 was. The Para 1 is nice, but had plenty of room for ergonomic improvements and design refinements. The Military could use a 4-way clip, and maybe some beefing up of the screws, etc. But, it's pretty darn great as it is.
Manix 2 DLC, Delica 4 FFG, Ladybug 3,County Comm H1 Ladybug 3 , Endura 4 FFG G10, C94 UKPK Leaf, Atlantic Salt, Military Camo DLC,Sage 1 Para 2 DLC, Delica 4.
- The Deacon
IIRC, the Military 2 is still a good ways out and Sal has mentioned producing both it and the current Military simultaneously, at least for a while when it is released. I think that's a smart move. The Military has been undergoing CQI since it first came out and it has a large an loyal following. I would imagine many of them will feel that changing to a totally different lock will make it a different knife.
Below is a copy of a post by Sal on February 7, 2011 in regards to a Military 2.
02-07-2011, 02:43 PM
Spyderco Forum Registered User Join Date: Sep 2004
Hi Seventynine,
We have had the Military on the design board for quite some time now. We've adapted a new lock for (stop-lock) and it's been in engineering. Then we'll make any ergo and clip adjustments and bring out a "2" model. Don't know yet if we'll use the new pivot bushing on the new Military.
We only have one engineer and Eric and I are responsible for the designs. While we also use outside designers, and we have Michael Janich in-house, the workload for so many models is often high.
I don't think we'll disco the original model when the new model comes out.
Hi Seventynine,
I wouldn't like the feel of being cut each time I close a blade either. If that's what's happening, it's way past time to consider why it's happening. :confused: This isn't a matter of lock-type, as even a slipjoint will not cut the user who keeps within its limits.Igi964 wrote:What do you think about the idea of Military2?
The Deacon wrote:IIRC, the Military 2 is still a good ways out and Sal has mentioned producing both it and the current Military simultaneously, at least for a while when it is released. I think that's a smart move. The Military has been undergoing CQI since it first came out and it has a large an loyal following. I would imagine many of them will feel that changing to a totally different lock will make it a different knife.
I think it absolutely does make it a different knife...just look at the Sage line. Personally i'm all about this stop lock...liner locks aren't my favorite. If the Military had a compression lock i probably would've bought one by now.
IMO, the nested linerlock design is great as is, but a Compression Lock Military would definitely have my interest..... :DEvil D wrote:.......If the Military had a compression lock......
"A man who is of sound mind is one who keeps the inner madman under lock and key."--- Paul Valery
Survive, Adapt, and Overcome...
I love the Military and every time the Milie2 gets mentioned, I always have the same answer;
I wouldn't change a thing.
I like that the clip can't be changed, I don't want holes all over my handle. Tip-down is the best, easiest and fastest way to open the knife. Spyder-dropping for the win.
New lock? Maybe. As long as its vastly an improvement. If it takes longer to close, forget it, I'm not interested, unless, like I said, its a vast improvement in strength.
The handle fits me just fine. I have large hands, and even when wearing gloves, love the handle.
I guess this is jut my personal tastes, but so far, I've yet to find a knife that I care more for than the Military.
I butchered two rabbits the other night with mine to make some delicious Stifado (Greek onion stew)!
- The Deacon
As I see it, there are four major considerations with a new lock. Ease of opening, ease of closing, weight, and ambidexterity. While I'm no fan of handed locks, a nested liner lock is hard to beat on the first two, and **** near impossible to beat on the third. It only loses points on the fourth and, at least for those members of the right handed majority too short sighted to think they may ever need to "go lefty" for a while, the last doesn't matter.HotSoup wrote:I love the Military and every time the Milie2 gets mentioned, I always have the same answer;
@Igi964
Never had a problem with military. The best knife in the market.
Are you serious?Donut wrote:It has been mentioned that the Military 2 is set to use the Stop Lock, which so far is new to everyone.
see my pics....
http://www.flickr.com/photos/vito72/
The other thing is the military is so balanced in my hand. It feels like an extension of my hand. Its big, but its light too. Switching between grips in hand are easy. Its like the knife is sitting on a pivot connected to your hand. The balance point is also right over your first finger, which I also love about my manix 2 and para 2. My g10 endura is around the same weight as the military, yet they feel totally different because their balance points are different. This makes the endura feel heavier. I have no doubt spyderco will do right with the military 2, but balance is another that makes the military so great in my eyes.
