Postby JacksonKnives » Thu Dec 29, 2011 1:57 pm
TBH, the Spyderco page is probably the worst description of them all, since it adds "(scandi)" which is something different again. ("Zero Grind Saber (Scandi)" at the bottom of the page is fine.)
Saber grind is called such because it resembles the grind of a saber (shocking, I know...)--flat bevels around halfway up the blade. "Flat saber" is redundant, but not inaccurate. "Hollow saber" is descriptive, but we're starting to mix terms. "High/full saber" is just silly--that's a flat-ground blade (or a "full-flat-grind.") Hollow Ground means you've used a contact wheel to do your grinding, and can give lots of shapes, but a "high hollow" usually describes a hollow that goes within 25% of the distance to the spine.
In any case, the question has been answered...
—Daniel Jackson
