Blade Centering
log man
Blade Centering
Postby log man » Sun Aug 28, 2011 7:37 pm
A few have mentioned with disdain that after re-assembly their blade wasn't centered. Even on a YouTube a complaint that the knife wasn't precision enough, because it didn't re-center after re-assembly.
The blade tip being centered as many know is simply an assembly procedure of getting it centered. It'd the assemblers job, and not difficult. When doing an assembly do not tighten any screws until they are all in and check for tip center, flex handle to center and snug a few screws, check again, re-do, once centered snug the screws, don't over tighten, when they stop firmly that's it. The pivot screw should also be snugged and backed off a quarter to a half turn. The blade pivot will always feel tighter at first and settle to smoother and easier, after a few dozen openings.
LOG
araneae
Postby araneae » Sun Aug 28, 2011 7:54 pm
I'm of the belief that if it doesn't rub, its okay for me. Perfect centering is a neurosis perpetuated by many a you tube reviewer and plenty of OCD knife nuts. It has no real effect on the knife during use.
-Nick
Just got:Rex 45 Para 3 LTWT, Harrier 2 LTWT
log man
Postby log man » Sun Aug 28, 2011 9:59 pm
araneae wrote:I'm of the belief that if it doesn't rub, its okay for me. Perfect centering is a neurosis perpetuated by many a you tube reviewer and plenty of OCD knife nuts. It has no real effect on the knife during use.
No, but the point is you can easily correct the centering of the blade with in reason. Why not? I first realized this with a Kershaw Assisted. They need to be disassembled for cleaning and occasional spring replacement.The liner lock wants to push the blade off center, but with careful alignment it will stay centered. Same with the Spyderco's, such as the P3 or Milly and Para's.
LOG
Waco
Postby Waco » Sun Aug 28, 2011 10:14 pm
I've disassembled my G10 Endura for cleaning and had no issues.
Javascript
Postby Javascript » Sun Aug 28, 2011 11:05 pm
Actually, we neurotics with OCD can appreciate symmetry without being knife nuts...and we sweat ZDP-189 thinking that if the blade isn't centered when closed it will be off-plane with respect to the longitudinal axis of the handle when opened. Not necessarily so, of course, but hey, we're neurotic. :D
Users browsing this forum: Accutron, dhowd, jensh, Mr Blonde, MSN [Bot], soc_monki, toocool006, Wartstein, wrdwrght and 28 guests
