poliwog is slipit in disguise????
gus88
Postby gus88 » Fri Aug 26, 2011 4:33 pm
so ive had my poliwog for some time now and have always appreciated and loved its uniqueness as far as shaping and ergonomics go. in fact it is in my opinion the most comfortable grip and im surprised more full "four finger choils" arent implemented in designs.
however today for the first time i tried testing the lock strength and to my surprise i could over come the ball bearing lock and snap the blade back in quite easily. in fact i can even do it with one hand after a couple tries.
i am not too afraid of the blade coming back in during use because of the ergonomics, and how the knife is designed to be used. but i am wondering if this is why they discontinued the knife? or do i have a faulty one?
both of my manix 2 with ball bearing cage locks do not do this :confused:
gbelleh
Postby gbelleh » Fri Aug 26, 2011 4:41 pm
I just tried mine, and no amount of force I apply to it, with one or two hands will overcome the lock.
It's not supposed to do that. Your ball must not be seating quite far enough to lock up properly.
:D :spyder:
araneae
Postby araneae » Fri Aug 26, 2011 4:47 pm
Send it in. Something isn't right.
-Nick
Just got: Ikuchi
Reject
Postby Reject » Fri Aug 26, 2011 5:32 pm
Just checked my poliwog, lockup is good.
But at one time I checked and found that I could overcome the lock. What I found was that dirt had gotten into the lock and stopping the ball from coming fully forward.
Give it a good clean first and check how far the ball is going into the lock.
Also push the back on the ball a bit and make sure there is good tension on the spring.
May not be the problem, but worth a check.
How much can a Koala bear?
gus88
Postby gus88 » Fri Aug 26, 2011 7:20 pm
thanks guys
will clean it up when i have some free time
but i think the ball has always been a little short in its lock
probably gonna send it in just to be safe, after hearing your knives are solid
gunnut35
Postby gunnut35 » Fri Aug 26, 2011 8:48 pm
My poliwog locks up strong and the only way I can close it is if I release the lock.
Nemonomicon
Postby Nemonomicon » Fri Aug 26, 2011 11:08 pm
Gus,
I had the same problem with one of my Dodo's. I sent it in and it was fixed.
Gunslinger
Postby Gunslinger » Fri Aug 26, 2011 11:23 pm
Mine locks up solid.
[SIGPIC][/SIGPIC]
v8r
Postby v8r » Sat Aug 27, 2011 5:27 pm
Mine locks up like a vault. Send it in they will take care of ya.
V8R
Opinions are like belly buttons most people have one:p
Postby Evil D » Sat Aug 27, 2011 5:41 pm
I just handled a Poliwog recently at the knife shop...that is a cool little knife...not really something i'd carry or use but i really liked the design and i agree the 4 finger choils is pretty cool. I'm sure different hand sizes could be an issue with a design like that.
But yeah i would definitely send it in, sounds like the ball isn't engaging enough. I wouldn't be forcing it closed anymore either just in case something gets damaged.
Users browsing this forum: 5-by-5, Accutron, Baron Mind, Bing [Bot], Bloke, Buddafucco, captnvegtble, Doeswhateveraspidercan, Google [Bot], JMM, JuPaul, Majestic-12 [Bot], MSN [Bot], pushcut, spambait11 and 31 guests
