What a nice surprise
Seanski
Postby Seanski » Tue Feb 08, 2011 7:09 pm
I guess, I should peruse the forums a little more often, however, I'm trying to pull myself away from the computer more often which isn't necessarily a bad thing. :o
I decided I'd go into my local knife shop and picked up a Spyderco Salt 1, and did not realize, until holding it that they are now sporting torx adjustable pivots!
Great job Spyderco, what a super addition to a wonderful knife. :)
Sean
Use your blades in the kitchen, it's great bonding time!
coelacanth
Postby coelacanth » Tue Feb 08, 2011 7:41 pm
Congrats on the new Spydie, and thanks very much for the heads up.
I've read Endura-sized Salt switched to screw construction a while ago but wasn't sure about Delica-sized ones like Salt 1. Good to know! :)
Delica Orange Jigged Bone, Manix2 Orange FFG, Poliwog G-10, Salt I PE Black, Chaparral
Seanski
Postby Seanski » Tue Feb 08, 2011 7:52 pm
You are welcome. :)
.357 mag
Postby .357 mag » Tue Feb 08, 2011 8:12 pm
Seanski wrote:I guess, I should peruse the forums a little more often, however, I'm trying to pull myself away from the computer more often which isn't necessarily a bad thing. :o
I decided I'd go into my local knife shop and picked up a Spyderco Salt 1, and did not realize, until holding, it that they are now sporting torx adjustable pivots!
Sean
It doesn't count without pictures!! :p
Seanski
Postby Seanski » Tue Feb 08, 2011 10:24 pm
Here are a couple I took quickly.
Salt1 006.JPG (51.06 KiB) Viewed 790 times
Salt1 005.JPG (54.38 KiB) Viewed 816 times
Whieee
Postby Whieee » Wed Feb 09, 2011 5:14 am
Now that's great news! Now I have to replace all my Salts with newer versions :D
(j/k ofcourse ;) )
Seanski
Postby Seanski » Wed Feb 09, 2011 10:02 am
Where ever you order maybe specify if you can, that you want the adjustable pivots,
because where I was a yellow one was pulled out and it was pinned. It's the "first in is
first out" doesn't necessarily apply to knife stock. :)
Users browsing this forum: 5-by-5, Doc Dan, JD Spydo, Larrin, toocool006, Wartstein and 34 guests
