Even though the Millie has 4mm stock thickness it has a very thin,week tip, the e4 maintains the 3mm thickness almost to the tip.So imho carry the military for sd (slashing doucheBags!Scottie3000 wrote:You are correct that the Millie and Para have thicker blades. Millie is 4mm, Para is 4mm, the Para 2 is 3.5mm, the Endura is 3mm, and the Delica is 2.5mm.
I agree that the Millie tip is thin, but don't discount its ability to work. There have been very very few knife duties that I wouldn't subject the Millie to. As an option, you might like to try carrying a multi-tool to compliment the Millie. With the two you have most all you bases covered. The Millie for knife duties, and the mulit-tool for all the prying, screwdriver, and plier work.HellHound wrote:Even though the Millie has 4mm stock thickness it has a very thin,week tip, the e4 maintains the 3mm thickness almost to the tip.So imho carry the military for sd (slashing doucheBags!) and the endura for utility, good combo.
Hhhm, i'll be all over that.kawr wrote:I dont like saber grinds. It defeats the purpose of a knife which is to cut things up. Saber grinds belong on swords and choppers. I do think a well done hollow grind would be pretty good on the millie and para though since overall cutting ability would be almost as good while adding tip and spine strength.
I'd probably be better off with a crowbar but that doesn't mean I can lug one around all the time.ace wrote:Put simply, if you are able to snap the FFG blad in 2 by applying sidays torque, you need a fixed lade with a minimum 3/16" thinck blade. You should never apply that much sidways torque to a folder.
Users browsing this forum: bbturbodad, bearrowland, Bing [Bot], EB31, ejames13, Google [Bot], NarwhalisnotKosher, skeeg11, Spydergirl88, TenGrainBread, The Meat man and 50 guests
