Wharncliffe Centofante 4
What is the advantage of a blade design like this? I've always read that a curved blade was better at cutting, so what's the idea behind the flat edge? I know they're discontinued but there's one for sale at the flea market...if there's something i've missed about these knives i may pick it up.
http://spyderco.com/catalog/details.php?product=201
Check out this great thread.
http://www.bladeforums.com/forums/showt ... p?t=621419
All in all, it's a great design for EDC. The low point with all its controllability is perfect for opening packaging.
I EDC my Saver Salt for similar reasons.
Ted
[SIGPIC][/SIGPIC]
[SIGPIC][/SIGPIC]
That's like saying a blade with a ton of belly will go flat.Evil D wrote:Ah.
The thing i'm curious about is how long the blade would stay straight after repeated use and sharpening. I bet it would eventually get a curve to it.
It you sharpen with good technique, it will just get shorter from the tip and in height.
Ted
[SIGPIC][/SIGPIC]
[SIGPIC][/SIGPIC]
Nope. Sharpened properly it should just slowly recede upwards. The biggest concern with a thin wharnie is tip degradation as it does the lion-share of the cutting. Then again, just don't use it as a linoleum knife and the tip should stand up well in VG10.Evil D wrote:Ah.
Advantages: easy to sharpen, aggressively cutting tip that doesn't deflect (blades with belly) or snag as it cuts (some hawkbills).
Disadvantages: like a hawkbill there are some tasks where having a belly is advantageous such as peeling labels and some chopping tasks.
- tonydahose
it is a great knife that feels tiny in pocket but when used it has more than enough of blade. i never liked the idea of a wharnie blade till i bought one, now i love them, plus they are pretty cheap as well. go get one!
WTC #1444 Always Remember
My knives
Spydie count: a few:D
My knives
- dj moonbat
- I. M. Nutts
- Dr. Snubnose
The yellow knife is more of a Sheepfoot design, not really a wharnie...The Centofante IV is a light sabre, very easy to sharpen and cuts like a razor, it did very well in meat tests, and there aren't too many knives out there that makes for a great slasher for SD like this knife. Plus the designer recently pasted away..so you won't be seeing anything more from Frank in the way of new stuff....run back..to the store and buy it...you won't be dissapointed....Doc :DI. M. Nutts wrote:Ooooh, I like a warnie!
That yellow one with the full serrations looks badass.
:cool: :) :cool:
I didn't like them until I got one and used it.... well, now I want Spyderco to make more... please!? :) I like them so much I had to improvise and make my own...
Get the Cento 4 quick before you are too late! Use it and you'll be converted. It really is a great all around shape, except for cutting on a cutting board, and even that can still be done.
- best wishes, Jazz.
It's more like the opposite. Mine all come with a slight curvature that I have to correct myself.Evil D wrote:Ah.
Im not good at sharpening, even with a sharpmaker. How get your blade good can your blade with an edge pro system? - Bladeforums user
Has anyone really been far even as decided to use even go want to do look more like? - Some Online Meme
Can someone tell me if this is a hollow grind or not? I don't remember from handling it. I'm really considering buying it. The other thing i'm not sure about is how thin the blade is...is it going to stand up to whittling and hard use like i've put my Delica through?
EDIT: yep it is....man that stinks, i'm not sure i want another hollow ground knife.
