Ultrafine ceramic triangle stone, how to clean ?
elsworth
Postby elsworth » Sat Jun 19, 2010 6:54 am
How do you clean the Ultrafine honing stone for the Triangle Sharpmaker kit ?
I was uncertain to use abrasive cleanzer, like Comet, as I use on the other triangle stones, or not. I goof up so many things in the past. I thought I would try using my head this time.
Thank you,
Elsworth
P.S. The ultrafine stone made a good difference in my edges achieved on the Sharpmaker. I'm glad I bought it.
Leatherneck
Postby Leatherneck » Sat Jun 19, 2010 7:15 am
I clean mine with a green scrubbie and some dish soap. Ceramic is pretty darn hard so you'll not destroy it easily.
USMC RETIRED
[SIGPIC][/SIGPIC]
dalefuller
Postby dalefuller » Sat Jun 19, 2010 7:28 am
elsworth wrote:How do you clean the Ultrafine honing stone for the Triangle Sharpmaker kit ?
Thank you,
Elsworth
Yeah... I like 'm too. I still strop, but the U/F stones do a great job at finishing an edge after sharpening. I use my strop now almost daily so I can avoid doing any serious sharpening on m EDCs.
I use Bon Ami and a green kitchen scrub pad to clean all my ceramics. I like Bon Ami because it doesn't have any bleach or other chemicals that are unfriendly to my skin or my septic tank.
I also clean them after each use, usually. That keeps me from having to do any heavy scrubbing and it keeps the stones' bite more consistent because I always start with clean stones.
Regards,
Dale
"If there are no dogs in Heaven, then when I die I want to go where they went."
~ Will Rogers, 1879-1935
D1omedes
Postby D1omedes » Sat Jun 19, 2010 9:21 am
The Sharpmaker DVD shows Sal recommending abrasive cleaners (ie. Comet and Bar Keeper's Friend) to clean your ceramic stones. I use those two brands with a no-scratch scouring pad and have had fine results.
The pads look like this.
2cha
Postby 2cha » Sat Jun 19, 2010 9:24 am
I haven't tried it yet, but some say a rubber eraser works.
marcus1
Postby marcus1 » Sat Jun 19, 2010 11:03 am
I have used the comet (same as Sal in the video) which works. I have also use GoJo (a hand cleaner a lot of mechanics use (it has small gritty particles in it).
I've also tried using VIM (which has a micro abrasive in it) and it works well.
1. Endura Black G2 SE, 2. Endura4 VG-10 SE, 3. Endura4 ZDP SE, 4. Caly3 ZDP PE, 5. Manix2 154CM CE, 6. Manix2 HXP FFG PE, 7. Delica ZDP SE, 8. Tasman Salt SE, 9. Ladybug VG-10 SE, 10. Byrd Crossbill, 11. Military S30V CE, 12. Blue Rescue 93mm FRN, 13. Grey Delica VG-10 FFG, 14. Blue Endura4 VG-10 FFG!
cckw
Postby cckw » Sat Jun 19, 2010 11:36 am
comet and my finger tips
skatenut
Postby skatenut » Sat Jun 19, 2010 12:02 pm
powdered household cleaner or a Lansky eraser block
cr123
mr. clean magic eraser
Postby cr123 » Sat Jun 19, 2010 3:20 pm
hi:
i've cleaned up the UF stones pretty nicely with Mr Clean's magic eraser. i cut a small piece (the size of bubble yum bubble gum piece) and go to town. the magic eraser also cleans up G10 too.
dialex
Postby dialex » Sat Jun 19, 2010 3:54 pm
2cha wrote:I haven't tried it yet, but some say a rubber eraser works.
Indeed, this is how I do. An ordinary pencil eraser cleans the stones fast and efficient.
elsworth
Postby elsworth » Sat Jun 19, 2010 3:55 pm
Thanks for the advice guys. Much appreciated.
I'm a Bon Ami guy too ! :)
Users browsing this forum: Bing [Bot], Google [Bot], legOFwhat?, max power, PeptoBizmo, standy99, The Meat man, tonijedi and 38 guests
