I've got a Centofante 3 and a Endura 4 that open real nice. This Police 3 is stiff. Very hard to open.
What to do about it?
Police very hard to open. How to fix?
- jabba359
I'll give you the usual answers. Try dropping a little lube in there and cycling it open and closed a bunch of times. I don't have a Police, and therefore don't know the particulars of that model, but if possible, you could also try loosening up the pivot screw a tiny bit.
P.S. Welcome to the forum!
I loosened it up completely and the pressure from the locks spring is so great, I think that keeps it from opening smoothly.
Alright, it was driving me crazy. I took it all apart. That metal rod used for a spring is brutally strong. What kind of washers are these(brass, copper?)?
What things can I do to this to improve this knives action?
- bohica1998
As mentioned above, a little mineral oil will work wonders sometimes. I have had several knives that were stiff and a little lube really helped. Even on two used ones that arrived a little bit rusty.
16 's and counting so far...
Current Inventory: C14SBK Rescue SE - C14SBL Rescue SE - C14PBK Rescue FG PE - C14SBK Rescue FG SE - C10PSGRWBK Endura USN CE Emerson Opener/Black Blade - LBK3HB Ladybug Hawkbill SE - C12SGY Matriarch SE G10 modded - C78PSBK Native 3 SE - C78PBK Native 3 PE - C41SBK Native 4 SE - C41PBBK Native 4 Black Blade PE - C41PSBBK Native 4 Black Blade SE - C77PYL SpyderHawk H1 PE - C106PYL Tasman Salt PE - C122GP Tenacious SE - BY22SBK Meadowlark Hawkbill SE
- The Deacon
Not all Spyderco knives, or even all Spyderco midlocks, open with the same degree of ease. Longer blades, in general, require a somewhat stronger spring in order to insure they close reliably and remain closed in your pocket. Aside from lubricating it with a good lubricant, and working the action a few hundred times, there's really nothing safe that you can do.
