Chinook 4
v8r
Chinook 4
Post by v8r »
How about a new version of a old theme! I'm thinking High Hollow ground blade with a thin edge, swedge grind on the spine, CBL lock,stainless liners G10 scales (Digicam or Foliage green), a handle shape similar to the current design(jimping like the Manix2).154 CM or S30v, makes no difference to me.What do you guys think?
V8R
Opinions are like belly buttons most people have one:p
slice22358
Post by slice22358 »
YES :eek:
Feeding the addiction
Proud member of The Cult of the Curved Ones-C.O.T.C.O.
bigkahunasix
Post by bigkahunasix »
How about using the Chinook I blade profile w/swedge and full flat ground. A true folding Bowie knife.
Been packing at least two Spyderco knives a day since 1984
[SIGPIC][/SIGPIC]
Lost Jaguar
Post by Lost Jaguar »
And a five-inch blade! The Bison lives in my dreams.
Prepare for Anything, Expect Nothing
v8r
Post by v8r »
Sorry no FFG for me.No real performance advantage in my opinion. :)
V8R
phaust
Post by phaust »
With the shape of the tip and a high hollow grind, what would a swedge add?
Josh K
Post by Josh K »
I think that high of a hollow grind would weaken the knife for it's designed MBC purpose. I'm much happier with the FFG.
Now a 5+ version? **** yes.
[CENTER]Dearly wishing for a H1 Military. And a M4 Military. Add in an old school 52100 Military with wood scales while you're at it.
Keep the curved RH TD clip please!
[/CENTER]
v8r
Post by v8r »
Josh you are probably right about the high hollow grind, but the original Chinook doesn't cut too shabby.Really the biggest dislike of the Chinook 1 is the lock and Tip down carry. :)
V8R
Josh K
Post by Josh K »
v8r wrote:Josh you are probably right about the high hollow grind, but the original Chinook doesn't cut too shabby.Really the biggest dislike of the Chinook 1 is the lock and Tip down carry. :)
What do you mean biggest dislikes? I love tip down! :D
A thin high hollow grind would probably cut better then the current FFG (except maybe long slicing cuts) but wouldn't be as strong. The goal was a MBC knife and you don't want the edge chipping out on you.
I'd be in for one with a ATR thickness comp lock though. Or a CBBL.
[/CENTER]
Post by The Deacon »
As is the case with all collaboration models, I would imagine any changes to the Chinook would require the designer's blessing. Obviously, I can't speak for James Keating, but IIRC, the C2 and C3 were intended to move it closer to his vision of the knife, so am not sure all, or even any, of the changes proposed would appeal to him.
v8r
Post by v8r »
A caged ball lock would be better than the current lock I think.
V8R
