Can I glue scales on a Stainless handle
dd61999
Postby dd61999 » Thu Apr 09, 2009 8:55 pm
Anyone done this?
I would like to glue a very thin g-10 scale on one side of my lava for more grip. anybody have any tips?
Jay_Ev
Postby Jay_Ev » Thu Apr 09, 2009 9:04 pm
I'm not sure about gluing on a G-10 scale but when people want more grip on a slippery stainless handle I have seen them put grip tape (similar to what would go on a skateboard) for added grip. Hope that helps. :)
Fred Sanford
Postby Fred Sanford » Thu Apr 09, 2009 9:05 pm
Yes you can. I would recommend using JB Weld to do it.
You can also get some skateboard grip-tape and cut it to shape for the sides. :)
“I'm callin' you ugly. I could stick yo face in some dough and make some gorilla cookies.” - Fred Sanford
SimpleIsGood229
Postby SimpleIsGood229 » Thu Apr 09, 2009 9:56 pm
I would rough up the surface with sandpaper for better adhesion.
God Bless Texas!
[RIGHT]Avatar courtesy of Dialex[/RIGHT]
Μολὼν λαβέ
2009 - Birth of the H-1 Spyderhawk! Thank you, Sal!
spyderwa
How to attach scales
Postby spyderwa » Thu Apr 09, 2009 10:34 pm
I have attached thin G10 and Carbon-fiber scales to stainless-handled Spyderco and Byrd knives with great results. Start by making a paper pattern and transfer it onto the thin scale material. Make the pattern slightly bigger than the scale so you can bevel it down to fit. Keep in mind that some of the newer stainless Spyderco knives have multiple clip screw mounting holes. Start with the older knives that take a scale on one side only until you get a feel for drilling the scales to match.
IMPORTANT! Remember that you need to take precautions with any of the synthetic materials, (and some hardwoods), because of their toxic/irritating nature. This means proper masks, goggles, ventilation, and dust control. Do not breath any of the dust. I also wear a snug-fitting nitrile/poly type gloves to protect my skin. I also use a hepa filter vacuum with the hose placed next to the work area when I use the Dremel because of the dust.
After cutting to shape with a small saw/scissors/Dremel, I test fit the piece. Then the stainless surface and scale should be cleaned with alcohol and set aside to dry. Some like to rough up the surface which is your choice. Using an quick-setting epoxy I apply a thin amount to the scale taking care to not go to the edge as it will squeeze out as you clamp it together. I use a credit card type piece of flat plastic to drag the epoxy evenly across the scale. When clamping make sure that you use a piece of wood under the clamp to apply pressure evenly across the surface. At this time make sure that you clean off excess epoxy making sure it does not get into the mechanism which would make your knife a fixed-blade. After it sets completely unclamp it and sand the edge of the scale down to the edge of the stainless at an angle matching the bevel that is already present. Finish to your desired texture and enjoy.
Final thoughts: Don't rush it. Make sure you take your time to ensure the best results. Also I would highly recommend starting on a less expensive knife like a Byrd to perfect your technique. Finally, please take care with the dust from the scale material. A nice knife scale is not worth lung, skin, or eye damage. Have fun.
spyderwa
Rare Spyderco Page
http://www.angelfire.com/trek/spyderwa
dd61999
Postby dd61999 » Fri Apr 10, 2009 12:38 pm
Thanks for the tips guys,
Any recommendation on what type of glue to use if I want to remove the scale at a later date
spyderwa
scales
Postby spyderwa » Fri Apr 10, 2009 1:49 pm
You would almost need to grind the epoxy off. I would treat this as a permanent procedure.
spyderwa
Rare Spyderco Page
Users browsing this forum: Bing [Bot], Bristlecone pine, Catamount123, Henri, mymojo34, N. Brian Huegel, p_atrick, skeeg11, Skinner, Spidey-Dawg, sv4, tbdoc4kids, TenGrainBread, VashHash and 46 guests
