cutting finger nails with a folder?
i see it mentioned a LOT. do you really do this? often? primary means of cutting nails?? toe nails, too?? HOW?
i prefer nail clipper for toes and victorinox scissors for finger nails. (to much personal information!!!)
i wouldn't know how to cut nails with a blade.
- peacefuljeffrey
Cutting finger nails with a folder? The very thought of it hurts :o
Spyderco's company motto
I'm a flamenco guitarist and sometimes I do it in a pinch before a show. I've found getting in between a serration on an SE blade works well-
What's the difference between a Republican and a Democrat?
A Republican wants to raise your taxes a little less then a Democrat and they both disagree on which freedoms you should have taken away . . .
vvVvvVvvV I have not used anything else for about 15 years. This is just one more reason that ALL of my EDC have some teeth. It works best if the knife has a small serration first in line rather than a large one . My Gerber EZ-OUT JR has the small serration first. I can't imagine a better tool for trimming finger nails. The Lady Bug 3 works OK because the large serration is fairly small. Most Sydercos have the large serration first and that is not ideal. I have considered adding one more small serration on my D4s. I will just have to cut into the kick a tiny amount. Those that insist on carrying PEs could easily add a single small serration. If you have never used a knife with a small serration first in line then you can't possible imagine how well this works. On edit; You do need to keep that first serration very sharp and near the factory angle.
Don't leave earth without some teeth. I carry a knife to open a can of worms.
I use my SE H1 Mariner for that quite often. works great, no problems or cut-off fingertips so far.
http://de.youtube.com/watch?v=ngFdNZX0REA
Dennis
That said....:Doc Pyres wrote:[...] It seems a little extreme, kinda like shaving with a Hossom, [...]
Dennis
- ClockWork
Call me high-tec, but I use nail clippers
:) Favorites: Black Paramil w/ D2 blade, PE Mini-Manix, S90v Military, Civilian, SE Dodo, PE Police, Sage
Vist my eBay store: Life and Liberty Gear
Tactical & MOLLE gear, Headgear and more
stores.ebay.com/Life-and-Liberty-Gear
- CombatGrappler
I always carry a pair of nail clippers in my pocket, so that is what I usually use. It is quick and easy, plus having clippers can make you a hero to any female coworker who is having a nail problem.
However, if I lost/forgot my clippers and had a hangnail or the like, I would not be afraid to "shave" it off with my Spydie. Sitting down and trimming all 10 nails with a knife would be kinda silly when you can get clippers for less than a buck, though.
Well, I guess I'm officially an old fart now. I've been trimming my fingernails with a pocket knife since I was a kid. I never carry clippers (they just aren't versatile enough to suit me) and I chip or break fingernails pretty regularly at work, so the pocket knife gets used. Yes, I have cut myself a couple of times doing it. So what?
- vampyrewolf
If I'm at work, I have wire cutters on my bench :p
The rest of my day, if I need to trim a nail I either use a knife or the file on my multi. Only have to resort to clippers for toe nails.
Coffee before Conciousness
- zenheretic
- The Deacon
Always have a nail clipper at home and keep a small one in my desk at work. Still, I do use a Kiwi if a nail breaks while I'm out and occasionally if it's only one nail and I'm just too lazy to look for the clippers. Can't recall ever cutting myself. Back when I use to garden and work on cars and bikes I'd use a knife all the time to clean under my nails.
