Syderco Hobbit Warrior?
- Lost Jaguar
- Banned
Wow!! what a pleasant surprise! I'm in
- Ian
- white cloud
- Mike Sastre
This Hobbit isn't a reference to Tolkien, it's to Bob Taylor, the original designer, who's well deserved nickname is "the Hobbit From ****".
Mike
http://www.RiverCitySheaths.com
"Kitchen Kydex" DVD sets available. http://rivercitysheaths.com/dvd.html
- The Mastiff
Tonie Nichols asked?
Eric G. Stated about H1 in the jumpmaster:
Being rust free is only one of it's strengths. It's also tough stuff. Likely tougher than most stainless steels, but more corrosion resistant and maintenance free than most carbon/alloy steels. It's easy to sharpen, but also very wear resistant. The Jumpmaster is evidence of some of it's strengths besides just corrosion resistance.Given that it is going to be produced in a steel specifically for salt water corrosion resistance, would it be correct to assume that it's main application will be some sort of seaborne special forces?
Eric Glesser Eric Glesser is offline
Platinum Member
BTW - the serrated Jumpmaster outperformed any other blade we’ve tested in edge retention.
Considering some of the truly "super" steels they have tested that is saying a lot. Joe
Old 02-10-2009, 06:43 PM
Platinum Member
Yes the blades were serrated. We believe the high performance is due to a few things. The bevel grind is straight at the edge with no curve and the bevel grind is high. With the combination of unique bevel grind, serrations, and steel, we believe this causes the blade to get work hardened more than most. We’ve also seen teeth on H1 bend before they break which shows how tough the steel can be. Add to the fact that it will never rust and this is truly a special piece.
The design was driven by Guy Rafaeli. He teaches the Israeli Navy Seals Martial Blade craft. He needed a knife design for their needs.
He worked on a design for quite a while and ended up with something he was pleased with. He thought that his design really looked similar to a previous design, which was the Echanis "Warrior" design.
Michael Echanis designed the original Warrior while he was working in South America. He send the original hand carved wooden model to Bob Taylor. Bob gave it to Al Mar to take to Seki for manufacture. Unfortunately, Echanis was killed before the model came out. (his plane mysteriously exploded in flight along with some government officials).
There have been a number of variations of the model over the years from a number of makers. We're currently working on the history. We'd like to provide a history of the design along with the model when it comes out.
Spyderco has been working on the design for a few years. Guy's requirement for 4mm thick H1 did take a while to develop. The design has been refined quite a bit and up alongside of the original Al Mar Warrior, one can see many differences. The full tang is skeletonized for balance and lighter weight.
Bob Taylor also made fixed and folding versions of the model as well. Bob used the name "Hobbit" but was asked by the owners of the name to not use the name.
We met with Guy Rafaeli in Germany at the IWA show and worked on sheath designs.
- Mike Sastre
Sal,
Let me know if you need any input on sheath design - done a BUNCH of Warriors, Hobbit Warriors, and Gaijin Warriors.
Mike
I have one of the Al Mar Warriors myself and they are indeed very neat knives. If youre looking for sheath solutions and need any ideas I'd be more than happy to help Sal.. I can picture the sheath design in my mind but I'd love to get a knife in hand and have the chance to build some prototype sheaths for you... Mike
THFH, thank you very much for the information.
There are no markings on the knife.
So I guess I have a fairly early version?
I bought the knife sometime in 1996-97?
Not that I will ever sell it, but what do you think it might be worth for insurance reasons?
I had a custom sheath made for it by Kenny Rowe (Rowe's Leather) out of Hope, Arkansas.
It is very beautiful with water buffalo inlay.
I will take a photo of it if anyone is interested.
Thanks again,
Ray
Thanks again,
Ray
