S30V v Aluminum, 4th of July
At the 4th July BBQ my wife says, "Do you have your knife" Wearing shorts I whip out my Mouse and hand it over. She opens it up and gets an ice pick grip, and lo, the pull tab on her can of diet whatever had failed so she proceeds to stab the top of the soda can until it surrendured. Jeez, good thing S30V trumps Aluminum.
- CombatGrappler
- dalefuller
Right... those things shouldn't be difficult for a Spyderco to handle. But the common denominator here is S30V.
I tell ya... much as I love my Para-Millie and my Ritter Grips (and I've had no problems with any of them), I'm feelin' a whole new wave of appreciation for steels like VG-10, 154CM, and D2.
Regards,
Dale
"If there are no dogs in Heaven, then when I die I want to go where they went."
~ Will Rogers, 1879-1935
Dale
I find the D4 and mini-griptilian actually work just fine as a can opener on thicker tuna-fish & baked beans cans while camping. I've never applied a twisting torque, but pointing the knife straight down like an icepick and slapping the butt-end with your hand to drive it into the can doesn't cause any problems. Even opeing a large sized can doesn't seem to dull the edge enough to make whittling wood take any noticeable more cutting force.
Of course, I've never tried using a serrated edge knife as a can opener, but I wouldn't be suprised to see chips if I did :rolleyes:
Also, I've never had a plastic zip-tie hurt either the plain or serrated edges of D4's or Mini-griptilians. But, I'm careful not to apply any twisting torque. Interestingly, the SE is easier for thick plastic zip ties or reinforced packing straps (like on lumber). The SE takes much much less slicing effort than the PE on plastic / fiberglass strapping.
I've always used a plain edge on those plastic coated, wire-reinforced "kids toy" twist-ties. The SE may be strong enough, but I'd rather let someone else test it - so I don't have to sharpen out any resulting chips
If anyone's used a SE blade as a can-opener, or cutting wire -- Please let me know how it turned out !
