Corrosion Test gets *NASTY*.......
My Salts are starting to annoy me with their utter bulletproof durability and refusal to rust, so it's time to break out the heavy artillery.....
Rock Salt dilluted in water, and since i now have a spare ultrasonic fogger head, i'll put the scrap fogger in the tank, it'll be filled with salt fog, highly corrosive salt fog
darnit, i really shouldn't have re-homed that Native after all, oh well, stop off at wally-world and pick one up anyway, also stop off at a pet store and get a hygrometer.......
Save the Dodo (Collect the whole set!)
Proud owner of 3 Blue Dodo's, SE#130, SE, and PE
Join the Cult Of H-1....
- bubbamets5505
MacTech wrote:Rock Salt dilluted in water, and since i now have a spare ultrasonic fogger head, i'll put the scrap fogger in the tank, it'll be filled with salt fog, highly corrosive salt fog
R.I.P. poor little scrap fogger. You died for a higher cause.
-Connor :cool:
'I ought never to act except in such a way that I can also will that my maxim should become a universal law.'
That is just plain nasty!
From what I gather, you're using a Walmart Native. So, which is going to fail first, the knife, or the fogger?
Will
"No one wants to look the fool. Everyone does the best they can. If they knew better, they'd do better" - old woman on the railway tracks to Sal.
Avatar by Datan!
Avatar by Datan!
I'm trying the Salt 1 first, i didn't feel like stopping at a pet shop or wally-world tonight, so i put the Salt in instead
the salinity of the water is quite high, so high in fact that it took a half hour for the fogger to get a usable amount of mist in the air, it usually fills the tank in seconds, 30 seconds to maximum fog density is normal
it *tastes* about twice as salty as seawater, seawater typicly measures out at 1.025% salinity, i'd hazard a guess the water in the chamber is at 1.055% or more
I think the blade will survive this. Not so sure about the coating on the other parts.
This problem probably isn't part of your world, but how about testing H-1's resistance to acid rain some time? I heard that stuff can get quite vicious.
Will
Avatar by Datan!
Avatar by Datan!
- uhiforgot
[quote="bubbamets5505"]If you could get a hold of some Chlorine that would be the ultimate corrosion test. ]I can personally vouch for Chlorine's corrosive properties to steel...
-Jeff
-Jeff
A very wise man once told me "Eat to live; don't live to eat." ...To my knowledge that's the only stupid thing he's ever said.
- rolyat1978
after 24 hours in *SALT FOG* the Salt 1 is still unscathed and gleaming brightly in defiance of it's Hyper-Saline bath
if i had any doubts about H-1 before, the're gone now, it's withstanding *rock salt* fog, the same rock salt that can corrode holes in automotive sheet metal (yes, admittedly automotive steel isn't a fair comparison, but still....)
- jaislandboy
- uhiforgot
How about some diluted sulfuric acid? :D pretty much the same thing :eek: :eek:jaislandboy wrote:cool tests Mactech....now where can we find u some Acid Rain? :confused: :p
-Jeff
when the smog pump fails and im mostly sure it will sooner then later
how bout a "wave " tank that splashes salt water or what ever you want on the blade
or even a auto dipping thinngy for a dunk tank
just thoughts
OT i got the knife and bottle opener back it was miss shiped and did you even get a real chance to use the OB knife it doesnt seem in that bad of shape
just thoughts
Lloyd R Harner III (Butch)
a step forward
working my way to a licence to drill
http://www.harnerknives.com
a step forward
- silverback
Pretty tough test, but is the knife a user?
If you really want to be evil, scratch the blade with a sharpmaker stone and repeat the test. That will be very realistic, since a user will inevitably get some scratches. Remember that a uniform steel surface of any kind will increase rust resistance.
I also like butch's automatic dipping thingy idea. :)
Few people think more than two or three times a year; I have made an international reputation for myself by thinking once or twice a week. -George Bernard Shaw
Go is a pursuit of such value that one can devote a lifetime to it and have nothing to regret. Why not, then, challenge the limit of your powers. -Toshiro Kageyama 7-Dan
The Salt 1 *IS* a user, with a conveniently pre-scratched up blade, as far as a dipping chamber goes, the fog chamber is rather nasty and has that angle covered.....
the knife is laying on it's side in the fog, one side facing up, one down, the fog generally condenses on the top side and runs off the blade, coating the back side, when i take the knife out of the chamber, it's dripping wet and water actually runs off the blade
the previous incarnation of the fog chamber was much simpler, it was the tank, an aquarium bubblewall spraybar and an air pump, it created salt spray, the fog particles are finer and can work their way deeper into the knife crevices and such, also salt fog has a higher air/water ratio which is what causes rust
hmm, maybe what i *should* do is go to waly-world (*groan*, HATE wally-world!) and pick up a Native, rust it in the fog chamber, then take it out, dry and clean it, then set the chamber back up as a salt spray chamber and rust it again, see which one is quicker.....
Still no rust, and it's *VERY* salty in there.....
How salty, you ask?, well, take a look at the *OUTSIDE* of the fog chamber.....
It's so salty that it's killed 5 of the 9 LED's in the fogger, and the actual *FOGGER* is starting to RUST!......
very nice test but i think the h1 is going to when this one.
"THE ROUGH RIDER”“FAR BETTER IT IS TO DARE MIGHTY THINGS..THAN TO TAKE RANK WITH THOSE POOR. TIMID SPIRITS WHO KNOW NEITHER VICTORY NOR DEFEAT.” THEODORE ROOSEVELT 1899
spyderco making mans oldest tool mans most advanced tool:spyder:
THE GREATSET POWER IS OFTEN SIMPLE PATIENECE
The only thing necessary for the triumph of evil is for good men to do nothing.
The fogger's still fine, amazingly enough, the Salt 1, as expected, is unscathed
i still have no idea of the salinity in the tank, but lets put it this way, i had to shut it down last night because the *AIR* was salty, i could take my green laser pointer and shine it against a dark surface, and even in a room lit by a 17" CRT computer monitor, the *BEAM* was clearly visible, there was a faint haze in the air
needless to say, for the safety of my computer hardware and home theatre, i stopped the test, no point in corrosion testing my *computers*, i *know* they won't fare well
hmmm.... maybe Spyderco should contract with Apple for the next incarnation of the MacBook Pro and Mac Pro, make the cases of H-1 steel
