David Lowry wrote:Almost seems as if there is some gunk in the pivot area. I would flush the entire pivot area with WD-40 while the pivot screw is nice and loose. I would then wash the entire knife with a good dish soap and hot water solution and then dry it. After that lube up the pivot with an oil of your choice and wipe off the excess.![]()
Fish wrote:Thanks much. Loosened the pivot, flushed with WD-40, washed with dish soap, blew out pivot with air compressor, lubed, and it is as good as new. Tightened pivot and there is little to no blade play and the action is smooth. Thanks again.
hey Piet! thanks for the Excellent Tip!Piet.S wrote:My Wave had a lot too when it came in.
I suggest to turn the pivots of both the blade and the lockbar loose first.
Then tighten the blade pivot in a normal way, this should get you a smooth action without play.
Then tighten the lockbar pivot, but only lightly.
The point is that the new phosphor bronze washers are thicker then the old nylon ones.
So the blade plus the washers are thicker then the lockbar.
If you turn the lockbar pivot too tight, you force the handle out of shape and the liners can not support the washers as they should.
Please try and let us know how it went.
Which screw is for the lockbarPiet.S wrote:My Wave had a lot too when it came in.
It's the first small screw back from the pivot screw. The following pictures of a Delica 4 being assembled should help:lowrider428 wrote:Which screw is for the lockbar
p_leonard wrote:Hi guys, came across the thread looking to find help regarding blade play on the D4.. I got mine just a few weeks ago and its been my edc knife since.. just general tasks, paper, cardboard, fruit and food prepping..
later today i found a bit of side to side blade play and i was hoping to het advice on what to do to eliminate it and weather its something i should expect from the D4 from time to time..
i understand that flipping or deploying the blade would have some force pressing down on one side (mine being the left side of the blade as i am a right hander) however i was hoping it wouldnt be the case.. since flipping knives is a fun thing, i wouldnt want to be all conscious with flipping it from now on..
thanks for your resonse in advance guys..
Thanks for the response Evil D.. makes a lot of sense with the pivots.. i'll probably tighten it and try to see if i can find that sweet spot.. im really hoping that the movement doesnt progress though..Evil D wrote:p_leonard wrote:Hi guys, came across the thread looking to find help regarding blade play on the D4.. I got mine just a few weeks ago and its been my edc knife since.. just general tasks, paper, cardboard, fruit and food prepping..
There is a very fine line where you can dial the pivot in and eliminate nearly all significant side play while still having a smooth easy to operate pivot. On some knives it's just a fact of life. I have a Para 2 that just doesn't have that sweet spot, at least not if I want the blade to drop freely when closing. On the other hand I have several Militaries that are rock solid but swing like a pendulum. I'd start by making sure the pivot is clean and then we'll lubed, and just tinker with the pivot screws and see what you can do. Blades with larger pivots and tangs seem to be easier to dial in, I assume because there's more surface area in the pivot to control lateral flex. A Delica has a pretty small tang, so it may never be as rigid as a Military.
Use a little blue Loctite on the pivot screws once you get a feel for where to dial it in at. That will help, but over time with use it seems most of them loosen up and need adjusting. As the insides wear and tolerances loosen up it will need snugged up again.
Users browsing this forum: Bdubs808, brancron, Craiger12, Deadboxhero, Holland, Majestic-12 [Bot], Naperville, PeaceInOurTime, PockettKnoife and 55 guests
