How could Spyderco improve their Clipits?
How could Spyderco improve their Clipit line, especially the upper-class US made Spydies?
They did the first step by updating from nylon to PB washers. But how could the evolution go on? My vote would be pivot bushings like Chris Reeve uses for his Sebenza.
What are your suggestions?
Greetz,
Thomas
Greetz,
Thomas
"I always thought it would be great to have two wives."
"No! You're thinking of a man with two knives."
They are very good already .
Few points maybe:
No rivets on the pivot anymore, all adjustable like on the new Delica/Endura
Option for fully serrated on all models (like Manix 80 mm, ZDP Caly, NavigatorII, ZDP Delica ect.) It seems that Spyderco is less inclined to make fully serrated blades lately. But maybe that's just me :confused:
Few points maybe:
- smcfalls13
Perhaps I'm simply uninformed due to my preference for Spyders, but could someone enlighten me as to what pivot bushings are and what purpose they serve?
This "How do we make them better" question was posed somewhere before, and I can't for the life of me remember my answers(they've probably changed anyway), but I think one that popped up a lot was to have better quality control in the Golden Facility.
Another I mentioned was more lefty friendly models, which Spyderco has very kindly done. Four way clips on the new Delica and Endura is above and beyond what I asked for.
:spyder: Scott :spyder:
"We make a living by what we get, we make a life by what we give."
-Sir Winston Churchill-
Pivot bushings are little tubes that are a little bit bigger than the blade plus the two washers. The pivot bushing runs through the hole in the blade tang, and the pivot runs through the pivot bushing. The purpose they serve is, that you have to tighten the pivot screw and you have a smooth open/close action without bladeplay. No more adjustments necessary. When you take your knife apart to clean it, you only have to assemble it correctly and tighten all screws and the action is like before.smcfalls13 wrote:...could someone enlighten me as to what pivot bushings are and what purpose they serve?
- smcfalls13
- Delica_Nut
- redhawk44p
Too late. They're already changing that design.Delica_Nut wrote:so far as I'm concerned the Delcia/Endura design is the best. I can use a quater to remove for cleaning and then replace. How has time to find the mini screw drived set? Sal has himself a get design and shouldn't mess with it.
"A flute with no holes is not a flute. A donut with no hole, is a danish."
Quietly lurking the Spyderco forum since 2003...
