Okay, I won a Raven, Crow, and Pelican from the byrd Slogan contest. Initially I received the Pelican, but got two Crows! :p No big deal, but the Forum Goddess Tazkristi sent me a PE Raven, which arrived this afternoon. Mahalo much Kristi!
Oddly enough, my Raven arrived in a byrd box depicting a Crow model on it. I already brought this to The Marketing Goddess' (Joyce) attention to avoid headaches and she said that they were already aware of the Raven/Crow "mix up" on the byrd boxes. :p
Upon opening I noticed it was very smooth. In fact a bit too smooth for my taste. I will tighten her up a bit. Of course the handle filled the hand very well due to it's width. Blade was pretty sharp, love them fine texture grooves! Then I noticed "it"...
Corrosion. The blade was pitted under the black coating and the liners had rust spots here and there. I used some Mother's Polish and got the spots off the liners, but the blade I could not help being that the rust appears to have formed under the nice flat black finish. Memories of CRKT knives I had here! :eek: The Crow fits my hand better, but I will be using this Raven to test out this byrd line. Why?
The rust on the blade, the rust on the liners...it's gonna happen eventually anyway with use here in Hawaii. Also the liner lock. It engages in different areas all the time, and is almost touching the other liner at times, missing it by about 1/16". Will it fail under normal use? Doubtful, but we'll see. The CE Crow got a good cleaning and back into the box it went. The Raven will get it's pivot tightened a bit and carried under the supervision of my C83.
NOTE: Special pic for ghostrider. As you can see, the place on my Raven's blade where the linerlock engages is NOT coated.
Mahalo for reading and again, a BIG mahalo much to our Forum Goddess: Tazkristi! :)
God bless :cool:
