Sal's Casual Bombshell Thread
SQSAR
Postby SQSAR » Sun Nov 27, 2011 4:09 pm
I can't wait to try ELMAX. I've never had a blade made of that.
xavierdoc
Postby xavierdoc » Sun Nov 27, 2011 5:10 pm
Is Sal implying there is a Carpenter steel version of the Bushcraft in the works (posted on Bladeforums)?
01 was the preferred steel for Bushcrafters. Since this model was designed by
Bushcrafters for Bushcrafters, we felt we should follow the proper path. Because the handle was so etraordinarily comfortable to use for long periods of time, I felt the handle could be also used for other outdoor solutions. My preference would have been S90V as an optimal compromise. Also, now we have Carpenter's version. Those two steels in a FFG will offer exceptional cutting power, edge retention and still provide corrosion resistance. More difficult to sharpen in the field.
...or does he mean Carpenters version of S90v (20CP)?
Sadly, I suspect the latter (but I was never much good at interpreting the message of the prophets!)
UKPK G10, UKPK Ti, Para 2CF&20CP, Stretch CF, Stretch CF conv, Manix2 M4,Endura Wave, Endura ZDP189, Pacific Salt, Captain, Gunting S30v, P'Kal, Gayle Bradley,Atlantic Salt, Spyderhawk, Crossbill, Wings slipit
Mules: CTSBD1, Super Blue, S90V, VG10, S35VN, Cos-3, M390 Fixed: Bushcraft, Warrior
-F1
Postby -F1 » Sun Nov 27, 2011 5:41 pm
Regarding a Tenacious (?) with non-8Cr13MoV steel:
sal wrote:We've been working on something with Carpenter.
DemskeetSkeet
Postby DemskeetSkeet » Sat Dec 10, 2011 4:33 pm
Gotta say this sounds good:
sal wrote:I must confess that, as a result of recent requests from forumites, I have begun to work on a design. Certainly nothing will happen in the near future, but I'm hoping to have the design finished with a concept model by spring.
Can't wait for a new Spyderco Karambit
Niles
Postby Niles » Sat Dec 10, 2011 8:19 pm
DemskeetSkeet wrote:Gotta say this sounds good:
Excellent! Thanks Sal! I'd be happy to do any field testing.
vito72
Postby vito72 » Sun Dec 11, 2011 7:42 am
Caly 3 for me VG-10 its enough, with G10 without bolsters in elegant blue navy or burgundy, i prefer blue navy.
razorsharp
Postby razorsharp » Fri Dec 16, 2011 11:09 pm
sal wrote:Hi Mil-Dot,
Actually, the name "Bodacious" is being saved for a large Rescue model designed for the Rodeo market. "Bodacious" was the name of a very famous bull that was impossible to ride. He has a special weave for his harness. We had a replica made of the original weave of the harness tha we plan to use as the scale texture.
this
chuck_roxas45
Postby chuck_roxas45 » Sat Dec 17, 2011 12:17 pm
Regarding the K390 mule.
Rutgrr
Postby Rutgrr » Sat Dec 17, 2011 12:18 pm
sal wrote:I have almost always carried a Ladybug. A back up or for those times when you don't want to pull out a larger knife. In my shirt pocket, it's convenient when driving.
I felt that for larger cutting chores like cutting up boxes, I wanted a little more purchase for control. This meant a tad wider and thicker. I also wanted a full flat grind. For the types of things that I cut, it works better. A full flat would require a thicker stock lest it become too weak, hence the thicker blade.
Now I almost always have a Manbug with me. It has replaced the Ladybug. I'm ready for a ZDP Manbug.
Me too :D
I have a FRN Manbug and it is really nice.
My :spyder:s
[SIGPIC][/SIGPIC]
SQSAR
Postby SQSAR » Sat Dec 17, 2011 1:48 pm
chuck_roxas45 wrote:Regarding the K390 mule.
That is great news!
pdptrow
Postby pdptrow » Sat Dec 17, 2011 2:33 pm
Very Cool.
A little information from the website below.
Bohler K390 has close to the same edge holding as A11 but is much tougher. Bohler's third generation particle metallurgy contributes to the toughness of the steel
This steel will be hard to grind, finish and sharpen. Once it is sharp it will stay sharp for a long long long time. :D
http://www.alphaknifesupply.com/zdata-b ... C-K390.htm
In the table above A11, M4 & Vanadis 4 Extra are shown for comparison purposes.
:spyder: Sage1, Stretch II CE-sold, S35VN Mule,Manix 2 CTS-XHP, Delica BRG ZDP-189 PE, Manix 2 CPM M4, Para 2 CTS-20CP :), M390 Mule, #Southard Flipper, Left Hand Millie, Para 2 204P :D, Delica Super blue
It is a mark of an educated mind to be able to entertain a thought without accepting it. -Aristotle
jabba359
Postby jabba359 » Thu Dec 29, 2011 10:02 pm
In a C37 Walker thread (someone also asks for a C22 sprint run, so I'm not sure exactly which of them Sal is referring to):
sal wrote:We were thinking of a sprint with Nishijin carbon fiber. We can also do Aluminum or G-10.
-Kyle
:spyder:
Latest arrivals: DLC M4 Shaman, Opus, Q Ball
http://www.spydiewiki.com
Chris_H
Lum Tanto (FB03) Sprint?
Postby Chris_H » Sun Jan 01, 2012 10:02 am
sal wrote: We're having some luckwith the brown canvas micarta that we use on the Temperance 2. Also the maker of the Dyad has found some micarta that we'll be using on a Lum Sprint next year.
Chris_H wrote: Sal -- A sprint with micarta and a Lum design? Are you referring to a Lum Tanto fixed blade (FB03) sprint?!?! If so, your post seriously qualifies as a "Sal's Casual Bombshell." :D
sal wrote:Hi Chris,
We just heard from the maker and the micarta deal fell through. We're looking at paperstone or maybe G-10. I guess it's a first comment on the Lum Tanto sprint.
Hmm... Leather or Boltaron sheath?
"All your :spyder: are belong to us."
** WTC # 1032 1533 **
DeathBySnooSnoo
Postby DeathBySnooSnoo » Sun Jan 01, 2012 11:12 am
jabba359 wrote:In a C37 Walker thread (someone also asks for a C22 sprint run, so I'm not sure exactly which of them Sal is referring to):
Whooo! Love more walker stuff!!
JLS
Postby JLS » Wed Jan 04, 2012 6:31 pm
sal wrote:FRN is probably the most strength per ounce over Titan or ?
FYI, we have a small fixed blade in-the-works (2.75" blade, skeletonized handle, FRN scales,sheath).
A new little fixed blade! Alright Spyderco!
42 Spyderco fixed blades and counting...
NAKK77
Postby NAKK77 » Wed Jan 04, 2012 6:51 pm
JLS wrote:A new little fixed blade! Alright Spyderco!
agreed this is awesome
Galatians 2:20
Total Surrender /FONT]
Rockcrawler
Postby Rockcrawler » Wed Jan 04, 2012 7:02 pm
Sweetness!
Cheers!
angusW
Postby angusW » Wed Jan 04, 2012 7:03 pm
Been waiting for something like this from Spyderco. Can't wait.
Member of the LH Military club.
My Spydies
DeathBySnooSnoo
Postby DeathBySnooSnoo » Wed Jan 04, 2012 9:19 pm
I've really been hoping that spyderco would do a small FB...but frn scales. That's a bummer. Micarta would have been nice...
jabba359
Postby jabba359 » Wed Jan 04, 2012 9:45 pm
DeathBySnooSnoo wrote:I've really been hoping that spyderco would do a small FB...but frn scales. That's a bummer. Micarta would have been nice...
If they're screw construction, then "Presto! Chango!" pull them off and build your own Micarta scales. Trust me, it's fun! :D
-Kyle
:spyder:
Users browsing this forum: AHarbuck, dlopaticki, jdw, Lucabrasi, sabb8pro2, TenGrainBread, Vol375 and 58 guests
