How to void your warrantee
- Mr Blonde
How to void your warranty
Finally found the perfect torx driver kit, and got two of them. The poor Dodo didn't stand a chance. Although it voids your warranty, it is quite enlightening to personally see how everything fits together.
Taking it apart was quite fast, two or three minutes tops. Putting it back together took a bit longer but still under ten minutes. A second time would be a lot faster.
Tip of the week: all you Dodo owners whose knife is a bit tight, try -carefully- loosening the smaller pins above the pivot pin. You can tighten the pivot pin as tight as possible, and then unscrew those smaller pins over it only half a turn. Smooth like butter.
Funny to see that two springs are used to propel the ball, a smaller one that fits inside the bigger one. Just like the recoil springs in the baby Glocks right?
Wouter
Wouter
- smcfalls13
Awesome Mr. Blonde, you've just given me the "how to dismantle a Dodo" manual.
It's definitely one of those knives I wanted to take apart and examine, just to see how it works. Still don't think I'll ever do it, but at least now I'll have a road map to put it back together.
I think your warranty definitely went out the window though...
:spyder: Scott :spyder:
"We make a living by what we get, we make a life by what we give."
-Sir Winston Churchill-
Very enlightening Mr Blonde. Thanks for sparing no expense for our education :) .
Certified Instructor - Martial Blade Concepts
"The longer I live the more convincing proofs I see of this truth, that God governs in the affairs of men, and if a sparrow cannot fall to the ground without His notice, is it possible an empire can rise without His aid?" Benjamin Franklin
- Michael Cook
Well, this confirms my suspicion that the Ball Lock is very similar to an Axis lock. It uses a ball instead of a cylindrical bar, and nested coil springs instead of two omega springs, but the idea is the same. I assume the ledge on which the ball sits is slightly angled, such that the ball can move a little farther forward to compensate for wear and to ensure a tight lockup.
Any idea if the lock would still work if one of the springs fails? That's a pretty nice feature on the Axis.
Yes, the spring system is very similar to my G27. Although the smaller spring sits behind the larger one on the same rod. In theory though, it probably works alot the same.
Ron
Ron
http://ront.smugmug.com/
Shine On...
Shine On...
- Dr. Snubnose
I second the notion of appreciating a peek inside the inner workings of a Spyderco knife. :)
For a perfectionist, and a collector rather than user, such as myself, seeing someone else take their Spydie apart is a real treat,.... due to the fact that I hesitate to even unscrew a pocket clip in order to change to tip-up/tip-down or what have you, or anything else for that matter. Since I am quite picky/paranoid about maintaining my collection in an immaculate condition, which means not unscrewing 1 screw, nor cutting 1 object with the blade.
"I Gave You Fair Warning .... Beware" -[infamous]-
Makes me wonder how a knife such as this is designed. For instance, the part that holds the ball and springs is a very odd shape. I would never guess it were part of the Dodo if it was displayed alone. Do computers do this or does Eric and Sal sit around hand filing prototypes until the fit and shape conform to the desired outcome? great pics, thanks
- Mr Blonde
Yes Ted, red loctite is the bane of the tinkerer! I don't know what the Chinese use on the Raven's and Crowfoot's clipscrews, but it's actually stronger than spydie red loctite. :mad:
One more tip for those of you who would like to start disassembling your own spydies; only use -perfectly- fitting torx drivers or you risk stripping screwheads.
Wouter
Wouter
[quote="Mr Blonde"]Yes Ted, red loctite is the bane of the tinkerer! I don't know what the Chinese use on the Raven's and Crowfoot's clipscrews, but it's actually stronger than spydie red loctite. :mad:
One more tip for those of you who would like to start disassembling your own spydies]
Yes indeed. I wanted to take my PT apart while on vacation so I got some cheap #6 and #7 torx wrenches at a hardware store. I damaged the pivot screw and a scale screw because the wrenches slipped and nearly stripped the heads. Luckily with the right equipment at home I was able to take it apart and put it back together properly.
