I need some help.
I need some help.
Does anybody with a jot singh khalsa have the blade wobble when the knife is open, there are small gaps between the blade and the liners which are natural but should my blade still move from side to side I would think the bushings should not allow this to happen. Thanks for your help.
I've no direct knowledge of the Khalsa, but no good quality knife should WOBBLE. I think if a knife has been used a great deal, particularly if it has a lockback, a tiny bit of movement, maybe the slightest WIGGLE would be acceptable. WOBBLE is no good!
Is the pivot pin tight? Can you try to adjust it? If that won't take care of it, I'd be on the horn talking to Spyderco re sending it in for service/repair. No WOBBLE! (I may make that part of my signature??)
Stare
Stare
