WD-40 on calypso jr
WD-40 on calypso jr
Could I use WD-40 on my knife or will it ruin it? What kind of oil do you guys recommend to use?
- The Deacon
Well, according to its manufacturer, WD40 is, among other things, a lubricant. Certainly not the best one, at least for knives, but, a lubricant none the less. While not ideal, it should not damage FRN or micarta, so it should be safe (in that regard) to use on any Calypso Jr. On the other hand, I would not use it on any of my knives, since I use them to cut food. Then again I don't use Miltec, Break Free, Dri-Slide, or any other "hi tech" lubricants for the same reason. Call me paranoid but I trust used car dealers and politicians more than I trust chemical companies.
- greencobra
FP-10 or Mili-Tec 1, mostly.
Referee in the Bowels of ****
Email: ST8PEN01@aol.com
Artwork For Sale
"...We few, we happy few...we band of brothers...For whoever sheds his blood with me today shall be my brother." - William Shakespeare
If you are not willing to stand behind our troops, by all means, please stand in front of them!
Artwork For Sale
I like WD40 on my frn Spydercos which need to be cleaned more often than oiled. It is thin enough that it never feels like it gums anything up but it does clean out grit and sticky tape residue, shines the blade up. And then it leaves just a little lubrication. I use it on all my knives to get tape off but usually oil the pivot with something else afterward.
Mike
Mike
As far as I know, WD-40 is metallophilic similar to MP oils for guns. Meaning it will form a chemical bond to a metal that is of a similar strength of that of water. Because of its lower surface tension, it will hence displace water, while many oils actually might trap water underneath an oil film. But the vapor pressure of WD-40 is pretty high, so it will evaporate eventually and much faster than heavier oils. Its lubricicity is also pretty low. Should be a good treatment if you got your knife wet and don't have other means to dry it out. or even worse to get a rusted pivot going, but for maintainance, I would prefere a heavier oil like engine oil, mineral oil etc.
- Jenner 515
I actually use three different products, WD-40 if there is something that needs to be removed from the blade, adhesives and the like, or to remove moisture from the pivot and lock. Three in one oil or Balistol for more thorough maintenance when an edc gets pulled out of rotation and back to storage box for a while.
I am a leaf on the wind - watch how I soar.
