Should i get a karambit or civilian?
I cant decide which to get so i was hoping someone could choose for me.
well, that depends on what your intended use will be.... personally, i would get a civvie. the "Oh holy crap!!!" factor is greater with that knife. just producing such a blade might alert an assailant to the fact that you mean business. or escalate the situation, as Daywalker would say, that's where training comes in, that's why it's important to train with your blades and with diferent situations. learning how to understand the assailant and the situation is crucial to your survival. hope this helped.
sven
steel is unforgiving... sharp steel even more so
sven
Welcome ebola,
Speaking from experience, I EDC'd a Civilian for over 10 years and now carry a kerambit a couple of times a week.
I would still say a Civie for several reasons. It is designed for someone with no training in self defense. It is more useable as a "utility" knife. It is less obvious in the pocket. When presented for SD it is probably a little more "scary".
I do plan to go back to the Civie when I buy a G-10 model as I don't wish to carry any of my CF models or any of my Alunimum ones either.
_____________
MAT<img src="spyder.gif" width=15 height=15 align=middle border=0>TER
_____________
Welcome to the forum! The Civie allows for a choice of tip-up or tip-down carry, and is suited to use in forward or reverse grip. The karambit is more suited to reverse grip, with the index finger in the hole, and with training can be used for some specialized techniques. As for choosing between the two, well, I am wearing both as I type this, although I must admit the karambit is of a different brand. Spyderco does make a very good karambit, and I will acquire one or two eventually.
Aloha and welcome!
I'd go Civilian. PERIOD. Unless that is, you are skilled at using a Karambit.
I personally do NOT like the ride height of the karambits, and well, if ya don't know how to use one, your pinky is gonna get it!
Go Civilian, OR the more economical route, the Matriarch.
Proverbs 16:3...Commit YOUR works to the LORD, and YOUR plans WILL succeed!
- dialex
Welcome to the Spyderco Forum. Another vote for the Civie.
<a href="http://users.pcnet.ro/dialex"><font color=blue>(my page)</font></a>
That's why I used the quotes on "utility". You can use it to open enlelopes, unlike the Kerambit. You could use it also for cutting a lot on non-flat items(rope, wire etc). I even used mine to cut up an apple once. And while I wouldn't suggest it for cutting-open boxes I did for a long time without hurting the tip. What killed the tip on mine was Concrete, do not try to cut concrete with it(it was an accident).
As far as the warrenty goes what are they going to fix? a faulty lock, a bad pivot. It is not like cutting things that aren't human is going to cause anything but the tip to break! If I break the tip off in someones ribs or skull does it get replaced for free?
__________
__________
I have not Civilian, so i cant judge and compare..., but i have Karambit and believe or not, its really brutal SD tool <img src="smile.gif" width=15 height=15 align=middle border=0>
Really suberb, its something like a "surgical machine" ;}
And in addition, wow, its perfect impact tool also ...
<img src="http://www.gunting-girl.com/000/karambit/DSC08295.JPG" border="0" alt="">
Simona V. :: joyful girl from the Prague, Czech Republic, www.gunting-girl.com
<img src="http://www.gunting-girl.com/000/k05.jpg" border="0" alt="">
