I was told by the owner of a knife shop that some people spray a thin coat of WD40 on the blade of the knife and let it dry. He said that this prevents rusting and will make the blade last longer.
I don't know if I should trust him, or that it is a useful tip. I would like to know before I do anything stupid to a new knife.
Maybe all of you know this already and I'm stupid?
Knife maintenence tip?
- ramlanrafie
Well Ive never heard that BUT, I personally always cover my entire blade and all metal parts with a good "lubrication system" like Dura Lube or the likes, let it lie over night so the metal can "absorb" it then wipe it clean, I may be wrong but Ive found my blades dont need any oiling in the locking systems and never get any form of rust on them, they always stay in gr8 shape.
Seeya l8tr
MaNcEr
It's Time To Kick @$$ 'N Chew Bubble Gum
Seeya l8tr
MaNcEr
You really don't have to oil stainless steel blades, unless you live in an extremely humid enviroment and/or use your knife consistently in a way that would promote corrosion. Just cleaning the blade with soap and water on a regular basis should be enough to prevent any serious rust from forming.
Living in Colorado, it's so incredibly dry that I can carry carbon steel knives and get by without oiling them.
If you do want to oil the knife though, I'd personally recommend mineral oil. You can find it at any grocery store and it's non-toxic, unlike WD40 and similar oils. Or, if you're really concerned about rust prevention, Sentry Solutions' "Tuf-Cloth" and "Marine Tuf-Cloth" are the way to go.
I use White Lightning for the pivot and a Marine Tuf cloth for the blade. WD40 is Stoddart Solvent and is designed to evaporate away.If it didn't evaporate it would cause corrosion of the metal.
Regards
Ricki
info@outdooredge.com.au
Spyderco Club Member
Regards
Ricki
- vampyrewolf
Why use WD40? It's because it's a water displacment thing. If you spray your blade, any moisture will actually dry up(try it on a bike frame, and see what I mean). I put gun blueing oil on my knives, and it works fine... does the same thing, and doesn't soak in or anything...
We all start with 10 fingers. Those with Spydies have 9 to spare, Still need a thumb. Good thing I still have 8 to spare...
