quote=JRinFL post_id=1722487 time=1686328817 user_id=26398]
This is a very important sentence, so I highlighted it. I try to be cognizant that my requests can often lead to a higher price if implemented.bobartig wrote: ↑Fri Jun 09, 2023 10:03 amIf you grab like 4 mules and pin them together with 3/16" chicago bolts, you will see there's enough variance that when you run your finger nail over them, it catches on some. It's like 1/3 of a millimeter here or there. The solution is to have the scales shy by ~1.5mm so the variances don't really show. Functionally there's no real difference.
In terms of manufacturing slop, the question in manufacturing is: "how much do you want to pay?" Can Spydero make all Mules identical to within 1/1000 of an inch? Probably. Do you wan them to cost $3000 each? Probably not. So when you think about how much more precise you would like their global mfring pipelines to be, you should always consider that lock-step with how much more you are willing to pay.
[/quote]
