C-60 Ayoob Campaign: No I Won't Shut Up
Re: C-60 Ayoob Campaign: No I Won't Shut Up
If it can be done well with no washers then the blade is much better supported against side to side play.
Dan
Dan
Wow!! that's interesting!! So there is just a slight glimmer of hope for a SALT version of the C-60 Ayoob down the road at some point maybe??? Because I can assure you there would be a lot of interest generated toward a SALT version of this C-60 Ayoob model I'm almost certain of it.sal wrote: ↑Sun Aug 14, 2022 6:20 pmHi Jim,
Amen!
Hey JD,
I guess I sorta lied. This maker just made their first knife with LC200N. The Subway Bowie. Apology. They do not have access to H2
On the washers, this particular maker does not use washers. They feel that it is better quality to polish the tang and liner so smooth that no washers are necessary. At one time, they were considered the best maker in the world, and then "The Rains came". I'll run the story down a bit later. I'm travelling.
As far as the washers go; I guess if you don't need them then that settles it. Off the top of my head I can't think of any obvious advantages that you could obtain by adding them other than it would be easier to disassemble in some cases.
BTW JD,
Kristi as been hunting down pair of Ayoob's for you for your efforts in this project.
Well.....I had a dream where I had this knife for some reason. It came about after checking it out in person saturday...so I'm going to go fulfill that dream today. Hopefully my flap of the butterfly wings here sends good vibes to Japan.
You can't just add washers. The spacing needs to match all around the knife at each standoff or backspacer.
If it works fine without side play, then why. Some older Microtech knives worked also without washers, where you had steel blade vs aluminium scales like in Socom.
Current collection: Lil Temperance G10, Shaman, Lil Native, Massad Ayoob cruwear, Smock, Street Beat, Street Bowie, Para 3, PM2 purple G10 cruwear, Canis, Rhino, Endura 4 K390, Watu, Kapara, Amalgam, Sliverax, Police 4 se K390, Police 4 pe K390, Khukuri, Barong, Ulize.
HALLELUHAH!!! Life Is Good!!! Only In America baby!!!! (as my ol' buddy Don King used to say)
GOD love you Sir and GOD bless the rest of the Spyderco staff members!!
Oh but be sure they don't get the C-60 Ayoob that belongs to Ms Joyce Laituri Because I know it's her favorite model too.
JD, please check your private messages. :)JD Spydo wrote: ↑Mon Aug 15, 2022 8:56 amHALLELUHAH!!! Life Is Good!!! Only In America baby!!!! (as my ol' buddy Don King used to say)
Kristi
- Buddafucco
Wylaco Supply:
PlainEdge... https://www.wylaco.com/spyderco/spyderc ... &limit=100
SpyderEdge... https://www.wylaco.com/spyderco/spyderc ... &limit=100
They both still show In stock at Pure Blades:
PlainEdge... https://pureblades.com/massad-ayoob-spr ... o-c60gpgy/
SpyderEdge... https://pureblades.com/massad-ayoob-spr ... o-c60gsgy/
•• Beau
- Capt'n Boatsalot
Thanks Budda! I was going to pass on this one, but Sal's insight about the maker pushed me back into the Buy column. Got a serrated one on the way from Wyalco.
MNOSD member 0030
Same here, thanks!Capt'n Boatsalot wrote: ↑Mon Aug 15, 2022 9:34 amThanks Budda! I was going to pass on this one, but Sal's insight about the maker pushed me back into the Buy column. Got a serrated one on the way from Wyalco.
- Capt'n Boatsalot
Don't want to clutter this thread unnecessarily (but will do so anyway)...Foundry81 wrote: ↑Mon Aug 15, 2022 9:48 amSame here, thanks!Capt'n Boatsalot wrote: ↑Mon Aug 15, 2022 9:34 amThanks Budda! I was going to pass on this one, but Sal's insight about the maker pushed me back into the Buy column. Got a serrated one on the way from Wyalco.
My Caly 3/3.5s are wonderful knives, and VERY smooth. Once I learned it was the same maker between those classics and the Ayoob, this just re-emphasized my need to support this specific maker and Spyderco.
MNOSD member 0030
As long as the subject matter of a C-60 Ayoob is part of your post you can feel free to talk all you want on this thread. I want this to be end-all thread of anything exhaustive, authoritative or even anything remotely related to the C-60 Ayoob model.Capt'n Boatsalot wrote: ↑Mon Aug 15, 2022 9:52 amDon't want to clutter this thread unnecessarily (but will do so anyway)...Foundry81 wrote: ↑Mon Aug 15, 2022 9:48 amSame here, thanks!Capt'n Boatsalot wrote: ↑Mon Aug 15, 2022 9:34 amThanks Budda! I was going to pass on this one, but Sal's insight about the maker pushed me back into the Buy column. Got a serrated one on the way from Wyalco.
Anything you or any other Brethren have to say about or related to the C-60 Ayoob model then let's do it all on this thread. And if it goes for 500+ pages then so be it. Your comments are always welcome here Brother.
Mine just arrived!
It definitely has a bit of a snaggletooth, which seems more or less obvious based on the angle you're looking at it from. I don't mind it. I just got the knife, so I've only cut a little bit of cardboard to test the initial edge at this point.. but I don't see it being a big deal in normal use.
Opinions on the snaggletooth aside, the blade is wickedly sharp. Overall construction/f&f is outstanding.. lockup is solid, w/o play.. ergos are great, if a little unusual.. scales/backspacer/lockbar are all flush with the liners, etc.. There's a lot to like here. With the exception of much-debated wonky serration at the tip, I can find no other issue with my Ayoob. It's definitely different from any other knife that I have and I'm happy to have the opportunity to own one!
Rick H.
My local shop has 4 PE and 3 SE. they do not have web orders but you can call and they will ship. Mark’s Outdoors in Vestavia AL. I manipulated most of the samples and they are top notch and the SE does not look wonky at all
Congrats JD! I just got shipping notification for my PE, can’t wait.
Well Congratulations are in order for you too my friend. You'll love I'm certain. If not let me know.
It's been a long haul getting this project done but in some ways that kind of made it more exciting when it finally arrived.
I do believe that the C-60 model is going to catapult to new levels. I don't believe that this knife ever got the accolades that it richly deserved. The future demand for this C-60 model will be much bigger than most anyone would have ever imagined.
I just hope that there will be more C-60 models in the future. But that will depend on how you all end up liking it.
Check out Jeff’s report in the “Talkin’ Story” thread: viewtopic.php?f=2&t=92355&p=1647827#p1647827
It’s simply miraculous this sprint got done.
That handle is thin! Length to spare too. I can get a full grip behind the first finger groove. I guess that adds reach and leverage, but didn’t realize that until I had it in hand.
Pretty good transition to SE on this one.
- Mark
