they're mighty fine utility knives. that's what I've used the Yojimbo 1, Ronin 2 and Yojumbo formetaphoricalsimile wrote: ↑Wed Jan 19, 2022 12:28 pmHmmm, love S90V, dislike huge knives, dislike the concept of carrying knives for SD, still strangely drawn to this...
On one hand I believe, you, on the other hand I've never found myself needing more blade than my Para 3 has. This would absolutely just be a "scratch the itch" purchase for mevivi wrote: ↑Wed Jan 19, 2022 12:35 pmthey're mighty fine utility knives. that's what I've used the Yojimbo 1, Ronin 2 and Yojumbo formetaphoricalsimile wrote: ↑Wed Jan 19, 2022 12:28 pmHmmm, love S90V, dislike huge knives, dislike the concept of carrying knives for SD, still strangely drawn to this...![]()
The Yojumbo has 50% more edge length than the Para 3, (all other factors being equal) Edge Holding is directly proportional to Edge Length so you'll be cutting 50% more material between sharpenings with a Yojumbo.metaphoricalsimile wrote: ↑Wed Jan 19, 2022 12:49 pmOn one hand I believe, you, on the other hand I've never found myself needing more blade than my Para 3 has. This would absolutely just be a "scratch the itch" purchase for mevivi wrote: ↑Wed Jan 19, 2022 12:35 pmthey're mighty fine utility knives. that's what I've used the Yojimbo 1, Ronin 2 and Yojumbo formetaphoricalsimile wrote: ↑Wed Jan 19, 2022 12:28 pmHmmm, love S90V, dislike huge knives, dislike the concept of carrying knives for SD, still strangely drawn to this...![]()
Or a 5 inch Spyderco Native Chief XL!Joshua J. wrote: ↑Fri Jan 21, 2022 4:56 amThe Yojumbo has 50% more edge length than the Para 3, (all other factors being equal) Edge Holding is directly proportional to Edge Length so you'll be cutting 50% more material between sharpenings with a Yojumbo.
Not a big deal for some people but at least it is a logical benefit for anyone to maximize the amount of cutting edge.
Now if only we could get a 5" YoMega/YoMaximum.
This is only true assuming that you're cutting evenly with the entire blade which I just doubt. Also I would guess blades with more belly tend to use more of the blade because of the way the blade naturally curves as it moves through the material.Joshua J. wrote: ↑Fri Jan 21, 2022 4:56 am
The process may have changed, but...
Yes sold out before I opened the page .Giygas wrote: ↑Tue Feb 01, 2022 9:52 amIn stock at ksf:
https://www.knivesshipfree.com/spyderco ... v-c253cfp/
That was fast.
Users browsing this forum: Bing [Bot], Google [Bot], Humbbaby, Manixguy@1994, Roefisher, SpyderCuse, troutinCO and 27 guests
