Hah! Wartsein is converting everyone, the biggest proponent of the Chap on this forum no doubt!
A cheap Genmitsu CNC could workJoshcrutchley1 wrote: ↑Sun Apr 11, 2021 6:00 pmI know I said it was brittle but that was an assumption based on the gray resin. I just tested a few of my test prints and they are all flexible but will eventually snap. It's not really comparable to plexiglass like I initally said.
Thanks! I hope to get access to a cnc to use more normal scale materials.sal wrote: Very cool Josh.
Nice! Thanks!Joshcrutchley1 wrote: ↑Mon Jan 24, 2022 11:12 amFinally got around to finishing the scales and uploading them to Thingiverse. https://www.thingiverse.com/thing:5215047
Here's an update with texture and some lightning holes that the stock scales have. https://www.thingiverse.com/thing:5219809Sharp Guy wrote: ↑Wed Jan 26, 2022 7:14 pm
Nice! Thanks!
I might try to print a set but I'm not sure how they'll come out on a FDM printer. I actually forgot you had done a set already. I thought about drawing my own when I did the back spacer. I still might. just need to decide how I'd like to do the texturing. Not sure I can do better than what's already on the FRN Chap. In fact, I know I'm not going to improve. Maybe just something different.
EDIT: I decided to go ahead an print a set using the slightly textured surface that I currently have on one of my machines. I also have a textured PEI surface that I might try. Camo green is on that machine so that's what I'm going with. I was thinking about neon green, red, or blue. I have some really nice colors.
I grew a set of scales...
EDIT 2: looking at that pic it looks like I could've bumped up the flow rate a little for the first layer for both scales. I'm sure what I'm seeing in the pic is hard to see in person but I might reprint after I test. I think I'll try the build surface I have that has more texture just to see how they turn out.
Josh did a nice job on the model. There's a few minor changes I'd like to make. So I'm going to model my own set in CAD when I have time
Did you use Inkscape to get the lines right?Joshcrutchley1 wrote: ↑Thu Jan 27, 2022 3:15 pmHere's an update with texture and some lightning holes that the stock scales have. https://www.thingiverse.com/thing:5219809Sharp Guy wrote: ↑Wed Jan 26, 2022 7:14 pm
Nice! Thanks!
Edit: Noticed a mistake and just updated the model so the first few people might have to redownload.
Again nice job. I'll have experiment with printing those on FDM. I'd have to print with inside of the scale down and use supportJoshcrutchley1 wrote: ↑Thu Jan 27, 2022 3:15 pmHere's an update with texture and some lightning holes that the stock scales have. https://www.thingiverse.com/thing:5219809Sharp Guy wrote: ↑Wed Jan 26, 2022 7:14 pm
Nice! Thanks!
That seems really hard. Could you explain the process?
Thanks. I just fixed another issue I saw.
Which part? It's very similar to how I make the mule scales explained here viewtopic.php?f=15&t=90080 , this video might help https://www.youtube.com/watch?v=dUiIAb1YqeMParaguy wrote:
I see. That's how I have been trying to design stuff but for some reason, I can manage to extrude it using this method. My lines probably need to be cleaned up or something. (I'm a complete beginner)Joshcrutchley1 wrote: ↑Thu Jan 27, 2022 11:16 pmThanks. I just fixed another issue I saw.Which part? It's very similar to how I make the mule scales explained here viewtopic.php?f=15&t=90080 , this video might help https://www.youtube.com/watch?v=dUiIAb1YqeMParaguy wrote:
Users browsing this forum: Brock O Lee, Majestic-12 [Bot] and 44 guests
