Hi MG2,Manixguy@1994 wrote: ↑Sat Jan 01, 2022 8:38 amHi vivi ! I ordered a Pacific Salt PE all black yesterday and once it arrives I going to take the 30 day pocket trial . I watched testing on blade coatings and decided to try a black blade and see what happens . I’m going to set aside my Dragonfly Salt and carry the the Pacific in right pocket . This will keep my left pocket free for rotation. Once Pacific comes in plan to run it until dull and then resharpen. If you disagree with this approach please let me know . Thanks again for all of this information . MG2
this is exactly how i feel about my pacific salt h1 se. i could absolutely get by with that knife and a pe fixed blade for outdoor uses and be totally happy.
Same here.
Thanks buddy. I’m trying to juggle responsibilities at home with weather and helping inside house. My CEO needs my assistance! Ha ha ! MG2
I like that edge, but I’m disappointed in the lack of socks.
the pacific salt is not a sock drawer knife. it's the knife you use so the others can sit safely in socks.
Hi Jason,
Jason Paul wrote: ↑Mon Jan 17, 2022 2:01 pmOK so I've had my Pacific Salt 2 PE in H-1 for a few weeks and have been carrying it almost daily. I'm not 100% sure where I stand on it right now.
Of course I like the corrosion resistance aspect of H-1. I'm also getting used to the ergonomics, having been one whose fingers don't quite agree with the finger bumps on the handle. I found that a very slight adjustment makes it more comfortable, and it's really not too bad. It doesn't quite "melt into my hand", but it's starting to feel pretty good.
I also like the weight of the H-1 blade, as Vivi mentioned earlier. Even though it's just a little heavier than the LC200N blade, it's definitely noticeable.
But the main negative is the grind. I'm an office guy, so don't get much opportunity for anything considered "hard use", but I've cut up some cardboard and definitely ran into some binding due to the hollow grind.
That said - I haven't sharpened it yet. Will reprofiling it to a lower angle help with this? It seems it would make it a bit slicier, but it's still going to swell up to a thicker spine, so it seems binding is still likely.
Thoughts on this?
Thanks,
Jason
Wow, that’s a lot of edc for plain edge h1. Thanks for posting.vivi wrote: ↑Mon Jan 17, 2022 4:13 pmthinning them out makes a big difference cutting cardboard.
https://youtube.com/watch?v=s4igtwiBK1o
The factory grind isn't the best for certain materials, but when you make the transition from edge bevel to primary grind more acute, they slice very well for a saber grind.
The FFG LC200N version will have an advantage here, but reprofiling the H1 versions bridges the gap to a degree.
I run mine a little thinner these days than it was in the video. No issues with edge damage, and it sees more use than any other folder I own.
So, I’ve just recently sharpened my first knife this way to give it a try. I typically prefer push cutting, and the way a more polished/refined edge feels when cutting. But I’ve been intrigued by your coarse edge advocacy! So I put a dmt coarse edge on an s30v endura, finished with a few swipes on a strop, and stopped there! I’m looking forward to seeing how it goes!
It definitely takes a little getting used to.DOUBLE D wrote: ↑Mon Jan 17, 2022 4:58 pmSo, I’ve just recently sharpened my first knife this way to give it a try. I typically prefer push cutting, and the way a more polished/refined edge feels when cutting. But I’ve been intrigued by your coarse edge advocacy! So I put a dmt coarse edge on an s30v endura, finished with a few swipes on a strop, and stopped there! I’m looking forward to seeing how it goes!
