Remove Loctite from G10
not_the_sharpest
Postby not_the_sharpest » Wed Apr 14, 2021 5:53 pm
So I was flipping my new PM2 clip from tip down to tip up. After stripping the torx heads on two of the screws I finally got the clip removed. Underneath the clip I discover there was loctite on the scales. What is the best way to get this out? I tried a little alcohol but that didn’t seem to do much. I tried a magic eraser and applying heat but am afraid to get much more aggressive since this was the olive drab G10 from the latest DLT exclusive.
soulspy
Re: Remove Loctite from G10
Postby soulspy » Thu Apr 15, 2021 7:53 am
I'd try 99% isopropyl and if that doesn't work, some acetone or fingernail polish remover. G-10 is quite resistant to solvents, so it should not effect the color at all, whereas abrasives will change the texture a bit.
Pokey
Postby Pokey » Thu Apr 15, 2021 7:57 am
This may sound dumb, but try more Loctite. Dab it on with a cotton swab. The wet Loctite may act like a solvent on the dried stuff.
DSH007
Postby DSH007 » Thu Apr 15, 2021 8:19 am
Hmmm.. I've had good luck with isopropyl alcohol prep pads in the past (though I don't think I've ever had that much loctite caked into a scale before..). Maybe some "goo gone" or similar..
Rick H.
Postby TkoK83Spy » Thu Apr 15, 2021 8:29 am
This reminds me of the thread Vivi started the other day when trying to disassemble his Native Chief. What the heck is going on all the sudden with the crazy amounts of Loctite coming out of Golden!?
23 :spyder:'s in 14 different steels
2 - Bradford Guardian 3's (Wharnie Vanadis 4E and 3V/Drop Point)
1- Zero Tolerance 0470
1 - Microtech Ultratech DE OTF
1 - Benchmade 940 (BHQ Exclusive/M4)
1 - WE Knives Gentry
Postby Evil D » Thu Apr 15, 2021 8:46 am
What I wonder more is there seems to have been a change from the evil Red Loctite to Red's equally evil cousin White Loctite. Or it's a matter of, white is less strong so we'll use twice as much to compensate. It also seems to be used by makers in different countries since mine was from Taichung and this is from Golden. I wonder why they don't switch to the paste stick thread locker? Might be easier to control it it doesn't effect cost too much.
How you carry yourself is just as important as what you carry.
VashHash
Postby VashHash » Thu Apr 15, 2021 10:44 am
Those loc tite sticks are awesome. So easy to use too. Just rub the screw on it and you have enough in the threads. I would suggest thinner or mineral spirits. The g10 can handle it.
Stuart Ackerman
Postby Stuart Ackerman » Thu Apr 15, 2021 3:12 pm
Methylene chloride is the solvent.
Google that in the USA.
What POKEY said is a good suggestion...use more Loctite, and that might clean it?
not_the_sharpest
Postby not_the_sharpest » Fri Apr 16, 2021 8:05 am
Thanks for the replies. I've tried acetone, mineral spirits, WD40, Goo Gone followed by some scrubbing with a plastic bristled brush. I may have made a little progress, but I have not found a miracle remover. I received replacement screws from Spyderco and they came with some 243 thread locker, so I'm going to try a little of that when I have time.
I breezed through that other thread mentioned and while I don't want to get into the debate about taking knives apart, switching a pocket clip should not be a big deal. This is by far the most trouble I've had changing one.
JRinFL
Postby JRinFL » Fri Apr 16, 2021 12:15 pm
Maybe you can call Spyderco and see what they recommend? Or send it in for warranty work? I don't know your location, so either might be difficult or impossible, practically speaking.
Not every choiless knife needs a choil, not every knife with a choil needs it removed. Not every big knife needs a Lil' companion. Wharnie for the whin! Friends call me Jim. As do my foes. Used to be JR in CT with a much earlier join date.
bbturbodad
Postby bbturbodad » Fri Apr 16, 2021 5:17 pm
I've never had to remove it from the surface of anything but brake cleaner has worked for me in the past to remove it from screws when heat wasn't an option.
-Turbo
kobold
Postby kobold » Sat Apr 17, 2021 1:36 pm
It is counterproductive to use loctite on pocket clip screws on knives advertised as a four-way clip position capable knives. It would be kinda better to include the clip and screws separately in a zip-lock bag and let the owner decide where to install the clip. The other two options would be to use much harder screws, or forget about using loctite completely.
Military: S90V, S110V, Fluted Ti. PM2 & Para 3: Maxamet. Native 5: Rex45, LC200N SE, S35VN SE, Spy27, Fluted Ti. Native Chief: S90V, Rex45.
Chaparral: Raffir Noble, Birdseye Maple. Tasman Salt 2 SE, Caribbean Sheepfoot SE., SpydieChef, Swayback, Manix2 S110V, GB2, Sage 1 Maxamet.
Incoming: Native 5 fluted CF
spy_kobold on reddit.
Senfkarte
Postby Senfkarte » Sat Apr 17, 2021 2:25 pm
This 100 % and the other points as well.
I remove the clip on every knife, because I'm a lefty. On nearly every knife the clip leaves an imprint in the handle, where it was installed in the factory.
On the hunt for my Spyder grail: G10 Manix 2 in CPM 20CV
SpyderGrill
Postby SpyderGrill » Sun Apr 18, 2021 12:32 am
I dont like the imprint either, but some people would strip a screw, lose 1, or something and would be a pain in the *** for customer service
kobold
Postby kobold » Sun Apr 18, 2021 12:49 am
The money saved on loctite could be used to preemptively include an extra screw.
SpyderGrill
Postby SpyderGrill » Sun Apr 18, 2021 1:07 am
Todays society there are not many men to handle this situation.
not_the_sharpest
Postby not_the_sharpest » Sun Apr 18, 2021 1:42 pm
So I tried using a little Loctite that came with the replacement screws to remove the dried on stuff. I dampened the are with Loctite on a q-tip, let it set for 30 seconds of so the scrubbed with a brush. Then cleaned the area with mineral spirits/acetone. In addition I used an Xacto blade to poke down in the grooves to break up some of the larger chunks. After repeating this cycle 8-9 times this is the end result. Not a silver bullet but it is better.
I wouldn’t mind if they shipped clips loose, but I can certainly see why they don’t. Eliminate the Loctite for the clip and I’d be satisfied.
I did reach out to CS to see I go they had any tips, and have not heard back yet. I also reached out to Henkel to see what they recommended.
Users browsing this forum: Bing [Bot], skeeg11 and 38 guests
