Mule Screws
rooster81
Mule Screws
Post by rooster81 »
Hi Everyone,
Could someone tell me what the size of the screws and barrel are for the halpern scales?
Thanks.
bobartig
Re: Mule Screws
Post by bobartig »
The bolts themselves are 3/16" diameter by 1/2" in length. I don't know screw dimensions, but I measure the head to be 13/64" with a T8 slot. That appears to be a normal screw size, according to the internet. I don't know the threading, but if you're buying replacements I assume you just get matching stuff.
rooster81
Re: Mule Screws
Post by rooster81 »
bobartig wrote:
Mon Feb 27, 2023 7:24 pm
Ok cool, looks like these ones then:
https://usaknifemaker.com/pivot-barrel- ... bh-ss.html
Thanks for the reply!
bobartig
Re: Mule Screws
Post by bobartig »
I bought some 3/16" bolts + screws from knifekits recently, and the screws are considerably larger than the ones that come w/ the Halpern scales. I'm making my own handles, so I can countersink to accommodate whatever screws, but if you are buying to replace for halperns, a lot of places don't list the screw head sizes and it can be hard to know if you're getting the size you need.
Re: Mule Screws
In this thread, I give screw dimensions that work well for the Mule, and I recall the screws/nut barrels were the same as those I received with the Halperns:
viewtopic.php?f=15&t=89796
tcarltonw
Re: Mule Screws
Post by tcarltonw »
They're 4-40 thread I believe
rooster81
Re: Mule Screws
Post by rooster81 »
Bolster wrote:
Tue Feb 28, 2023 9:53 am
Thanks for the info!
rooster81
Re: Mule Screws
Post by rooster81 »
I contacted the company and they said the screw head diameter is 0.0153". That seems small, right?
Ramonade
Re: Mule Screws
Post by Ramonade »
rooster81 wrote:
Thu Mar 02, 2023 11:32 am
On the G10 set of scales Spyderco provides the screw head diameter I mesured is 0.206" if that helps.
rooster81
Re: Mule Screws
Post by rooster81 »
Ramonade wrote:
Thu Mar 02, 2023 12:42 pm
It does, thanks. They added an extra zero, the the screws are apparently 0.153 in diameter, but that still doesn't make sense to me because the barrel is supposed to be 3/16, or 0.1875.
Connman
Re: Mule Screws
Post by Connman »
My Halperns are 4-40 , 0.195 head diameter T8 , the other screw is a knife kit , 6-32 , .246 head T10
You can see how I countersunk scale for bigger screw.
The USA knife screw size is a catalog mistake , they use the 2-56 in their smaller pivot barrels , they use 4-40 in their 3/16 barrels.
Ramonade
Re: Mule Screws
Post by Ramonade »
rooster81 wrote:
Thu Mar 02, 2023 5:05 pm
I have been after 3/16 barrels and matching button head screws in order to try and make screw-in set of scales. I've found a supplier but it's Brisa, in Finland. I don't reckon it will be worth importing in the USA.
USA Knife Maker seems to have stuff that fits perfectly with no hassle !
They have many 3/16 barrels, the ones with 6-64 threads will fit these screws : Screw 6-64 Button Head SS .20" Thread Length Torx T10 - 10 pack
Toker
Re: Mule Screws
Post by Toker »
This is what I used from USAknifemaker.
Titanium Screw 4-40 Button Head 3/16" Thread Length T8
SKU: FKPSCW-CTS-4102
rooster81
Re: Mule Screws
Post by rooster81 »
Thanks again everyone! I ended up ordering the barrels and screws from USA knife maker, see the links below. The screw heads are slightly bigger than the holes in the halpern scales and stick out a bit but everything fits fine so no big deal. They were the only place I found that wasn't sold out of barrels and screws.
Barrels:
https://usaknifemaker.com/straight-pivo ... -pack.html
Screws:
https://usaknifemaker.com/screw-6-64-bu ... -pack.html
