Magnacut Mule Box Date Codes: KU & LU
Bamalt1
Re: Magnacut Mule Box Date Codes: KU & LU
Post by Bamalt1 »
Mine's also KU.
S35VN PM2, Spydiechef, M4 Manix 2 XL, Rex 45 Shaman, Kapara, M4 PM2 Tanto, Ultatech BH, Techno 2, 20CV Yojimbo 2
FullScaler
Post by FullScaler »
I got mine 2 days ago and have a new code to add. AU (gold baby) Also noticed the white color on the box end flap as well as the warning labels were different, it's a sticker on the AU version.
Https://BladeProtection.com
Ramonade
Post by Ramonade »
It's written MT31P , the S45VN one for your first box ! That must be the reason :')
(Or the joke flew right by me, once again !)
FullScaler
Ramonade wrote:
Thu Dec 23, 2021 9:09 am
Ahhhh, you are right. Lol, I musta grabbed the wrong box when I checked and didn't notice it was the wrong one. Just double checked and they are both KU.
burlyspyder
Post by burlyspyder »
If I recall from another discussion, it's a month/year code. K=11, U=21. So it may be that the LU one was finally finished in December. Remember, there aren't 1000 being run in parallel for all production steps, so there are bound to be some that spill over into another month.
For the AU code on the s45vn, that would mean it was made a few months before release, so not sure if this holds up across the board for mules.
I only have 1 other Mule and will check the box to see if the letter code aligns close as to release month. EDIT: My Zmax Mule is FU, (F=6, June) so I think the above holds. Also, checked a few other older boxes, and the second letter does indeed go backwards through alphabet the older the knives are.
-burly
:bug-red: H1, M4, 4v, 10v, Hap40, s90v, s110v, BD1n, Maxamet, Magnacut
MT; Z-max, Z-wear, Magnacut, SRS13, Rex76, M398, T15, K294, ZDP-189, HIC, AEB-L, SPY27, 15v
Other: D2, White#1, Blue#2, SuperBlue, VG-10, 204P, 20cv, s30v, s35vn, s45vn, s90v, HIC, TC71
Post by The Deacon »
burlyspyder wrote:
Mon Jan 10, 2022 1:20 pm
If I recall from another discussion, it's a month/year code. K=11. So it may be that the LU one was finally finished in December. Remember, there aren't 1000 being run in parallel for all production steps, so there are bound to be some that spill over into another month.
For the AU code on the s45vn, that would mean it was made a months before release, so not sure if this holds up across the board for mules.
-burly
True, and there's also the fact that the month in the date code is the month in which the knife was packaged, not necessarily the month in which it was manufactured.
Wandering_About
Post by Wandering_About »
I threw away my Mule's box shortly after getting the knife out of it and never did look at the date code. Ignorance is bliss???
MNOSD member #0035
