Magnacut Mule!!!
Re: Magnacut Mule!!!
Seven listings currently up for sale on ebay with prices from $190-230, only one of them in hand by the photos. Five have already sold for prices from $130-200.
I’m cutting up some bandanas to help a co-worker make masks. The fabric cutter, is fine for the long curves and straightaways, but it doesn’t work well when it comes to fine detail.
The new MagnaCut Mule does a superb job with its razor sharp tip for the spots where I miss with the pizza fabric cutter. The edge retention is outstanding; haven’t had to sharpen it yet.
Congrats to everyone who scored. I missed out but I have 2 other Spydies in the mail at the moment so no hard feelings.
Pokey wrote: ↑Fri Dec 03, 2021 10:37 pmI’m cutting up some bandanas to help a co-worker make masks. The fabric cutter, is fine for the long curves and straightaways, but it doesn’t work well when it comes to fine detail.
Nice! Poor bandana though...
I planned well ahead. Ready to pull the trigger the second the mule was available and the website was unresponsive for over 30mins. Now I'm seeing them on ebay for >$200 which makes me question how this whole process is working for the people, like me, that just want to use and test the blade steel.
I've done a google search with "spyderco forum mule dimensions" and found some answers for the dimensions of the holes.
However, I've seen that there was some change between mules. Is there someone that can tell me what size of pin I should prepare?
I have a lot of stocks but it's only 2mm, 2,5mm, 3mm and 4mm brass pins and some 6mm mosaic pins. I know that the fact that I'm using the metric system might be a problem.
I had found this post from hickster :
I guess I'm gonna order some in Europe with the 3/16" measurement, and not try to adapt the brass rods I already have. I'm just not sure about this and want to buy the good material for the job.
3/8" = 9,525mm 1/4" = 6,35mm 3/16" = 4,7625mmThe large holes are 3/8"
The thong hole is 1/4"
the pin hiles are 3/16"
hickster
MNOSD member 004* aka Mr. N5s
