Well, no duh eh. Z-Max is not a stainless steel, it will corrode.
This is the corrosion build up after 1 week of processing moose hide. Mostly cutting membranes and muck off, some shaving hair off, and lots being wet.
It has mostly cleaned off with a good scrub but there is some pitting and discoloration.
The Halpern scales are easy to remove and make the clean up something I should do daily instead of weekly.
Well heck, it's a mule. Work it hard and send it back to the stable.
Z-Wear loaded and ready to pull.
Thanks Spyderco for the great steel and excellent platform.
Z-Max Corrosion
Z-Max Corrosion
Spyderco: Tenacious G10, Waterway, Para 3 Spy27, Pacific Salt H1, In the Mule Team Stable(Z-Max, Z-Wear, S45VN, Magnacut, SRS13/SUS405, M398, Aeb-l, 15v)
- standy99
Re: Z-Max Corrosion
Thin layer of felt sprayed well with inox food grade put either side between scales and tang will stop that…..
- VooDooChild
Re: Z-Max Corrosion
Mine also has corrosion on the handle under the halpern scales.
- WilliamMunny
Re: Z-Max Corrosion
Thanks for the post. Please let us know if the z-wear does any better or worse with corrosion. I think it should be a bit better but never sure.ykspydiefan wrote: ↑Tue Oct 05, 2021 12:11 pmWell, no duh eh. Z-Max is not a stainless steel, it will corrode.
Endura AUS-8, Manix 2 S30V, Alcyone BD1N, PM2 Micarta Cruwear, Native 5 Maxamet (2nd), Para 3 Maxamet (2nd), Magnacut Mule, Z-Wear Mule, BBB 15V Manix 2, REC PM3 10V Satin, Dragonfly Salt 2, GB2 M4.
Re: Z-Max Corrosion
Z-MAX contains about 4.00 of Chromium
while
Z-WEAR contains about 7.50 of Chromium (almost twice more than Z-MAX)
So, definitely Z-WEAR is much less prone to corrosion than Z-MAX. Though both steels ain't stainless anyway
while
- standy99
Re: Z-Max Corrosion
Part of my decision to attaching handles for good was due to the wicking of water underneath the scales
