In a way I wish I had saved the factory sharp edge for this project. Z-Max vs Moose hair/hide.
Not much to say other than, it would be nice to have a Z-Max Ulu to do this work with.
I keep my diamond stones near by and touch up along the way. Hair came off easy.
I'll skip the gooey bits on the other side. But, I will say that a really sharp knife is a pleasure to use when removing thin membranes.
It is hard to tell how much time I have saved with having a high edge retention steel. It feels like a lot of savings, less sharpening, and fast work with a sharper blade.
Check back in 6-8 months and this hide just may look like slippers.
Sharp enough to shave....
Spyderco: Tenacious G10, Waterway, Para 3 Spy27, Pacific Salt H1, In the Mule Team Stable(Z-Max, Z-Wear, S45VN, Magnacut, SRS13/SUS405, M398, Aeb-l, 15v)
Re: Sharp enough to shave....
Awesome!
By the way, is it blue-died stock scales on the Mule? Or some aftermarket ones?
Wow! Looks like you found just the perfect tool to shave your slippers!!
Scales are Halpern. 3d textured G10. I might like them a little fatter but no complaints. Good grip in the goo.
How did you get the moose to hold still?
Well, hide tanned. 1st project done. Now at least one mule has a nice place to rest after all that hard work.
