In the name of mule science
standy99
Post by standy99 »
Having the last 3 mules since the reboot awaiting handles I thought I would run a little science experiment
Secret ingredient added….. :winking-tongue
Chose to use the handle so it doesn’t upset the blade.
standy99
Re: In the name of mule science
Post by standy99 »
Results
Z-Max took a bit of colour
SPY27 looks like it cleaned it more than marked it (Z-Max on top)
To be continued….. New secret ingredient added…. :nerd
Fireman
Post by Fireman »
Why no catsup?
Did you swab with alcohol first?
:winking-tongue Mule Team Army 001
MNOSD 008 :usflag
Image Stable Mules; Z-Max, Z-Wear, Magna Cut, SRS13, Rex 76, Rex T15.
standy99
Post by standy99 »
Fireman wrote:
Sun Aug 15, 2021 5:41 am
Why no catsup?
Yes, cleaned before secret ingredient added.
Also a full 24 hr test not one of those rushed YouTube ones.
Fireman
Post by Fireman »
Tomato sauces are pretty acidic
It will clean pots and pans or take the season off a cast iron pan.
Not scientific and definitely gross but a more real world situation, but I wonder how a blade would react to being wrapped in a sweat soaked shirt for a day. Maybe rub a few blades with the sweat filled shirt and then wrap it up in a ziplock bag and compare?
MNOSD 008 :usflag
Unless that's Grey Poupon, I don't think it really counts as mustard.
standy99
Post by standy99 »
Bolster wrote:
Sun Aug 15, 2021 6:05 pm
Real mustard out of a glass jar….Not that toxic squeeze bottle stuff you :usflag guys have on hod dogs
Results are in for Mustard
standy99
Post by standy99 »
New secret ingredient…..
Results for Tomato paste
Not that much
Z-Max took a slight colour but nothing more than mustard
archangel
Post by archangel »
Cool thread, looking forward to seeing more results!
Michael
legOFwhat?
Post by legOFwhat? »
Great idea! I dunked a PD#1 mule in a pickle jar of secret liquid for a couple days, but it didn't darken it up as much as I was wanting...I'll see if I can come up with a comparison pic.
-Larry
MNOSD #0049
Josh Crutchley
Post by Josh Crutchley »
I thought for sure Z-Max was going to look way worse. Very interesting can't wait for more results. I wonder how much difference there is from the surface finish because I don't think the holes are finished to the same degree as the flats.
standy99
Post by standy99 »
Third secret ingredient (this might see some results)
Results for Malt Vinegar
Been flat out with work so will take the clean up shot in daylight tomorrow
As promised
Z-Max only
Fireman
Post by Fireman »
I think the sweaty shirt ziplock bag test is probably the most real world rest for my uses. I may have to try that.
MNOSD 008 :usflag
standy99
Post by standy99 »
Been flat out with work so will take the clean up shot in daylight tomorrow. Bit of a rust mark from vinegar on one of the mules.
Fireman
Post by Fireman »
Time to break out the battery acid.
MNOSD 008 :usflag
standy99
Post by standy99 »
Updated above :bug-red-white
Fireman wrote:
Thu Aug 19, 2021 7:38 pm
Will leave the battery acid to you… Happy to do the test if you send me the mules.
archangel
Post by archangel »
standy99 wrote:
Fri Aug 20, 2021 1:25 am
:') Good one!! :clapping-hands
Michael
Rp5
Post by Rp5 »
Good thread.
standy99
Post by standy99 »
:thinking One more secret ingredient to do….
Any suggestions besides battery acid :')
WilliamMunny
Post by WilliamMunny »
standy99 wrote:
Sun Aug 22, 2021 2:39 pm
What about…
Salt water - would be good to see how knives used around the ocean or even bays like the Chesapeake.
Lemon juice - just something to simulate food prep.
Raw meat - to simulate food prep and field work.
I am not sure if you got the z-wear but I would love to see the same tests with it.
Great posts.
Endura AUS-8, Manix 2 S30V, Alcyone BD1N, PM2 Micarta Cruwear, Native 5 Maxamet (2nd), Para 3 Maxamet (2nd), Magnacut Mule, Z-Wear Mule, BBB 15V Manix 2, REC PM3 10V Satin, Dragonfly Salt 2, GB2 M4.
