I guess #1 is my go to. Just drilled to size and used epoxy but that was with a pin made from g10. I would like to try #4 and grind them down to look tike pins.Bolster wrote: ↑Mon Apr 05, 2021 10:55 amWhen you pin your scales to a mule, how do you do it?
(1) Get pins the size of the holes in the mule tang, use them like alignment pins, slide the scales on, and rely on the epoxy to keep scales and pins in place. Any pin material will do, brass, stainless, whatever. Sand the ends flush as you finish the handle.
(2) Drill your scale holes with a very slight taper, widest to the outside, and use a brass or copper pin that's malleable. Then put on the scales and peen the pin so it widens into the slightly oversized hole. This method basically wedges the scales to the tang and does not rely exclusively on an epoxy bond. (I think this is the traditional olde-tyme slipjoint method.)
(3) Use rivets
(4) Don't use pins, use corby or sex bolts or screws (please give reason why this is better?)
(5) Other
I don't like to rely solely on pins to hold the scales in place. I'm sure we've all run across old knives with loose scales. I want my knives to be fully functional fifty or more years from now. Wood scales exacerbate the problem. Wood can change shape over time. Modern epoxies can mitigate future problems.Bolster wrote: ↑Mon Apr 05, 2021 10:55 am
Xplorer wrote: ↑Mon Apr 05, 2021 10:43 pmAlthough I've done a few Mule handles using pins and epoxy, I much prefer using corbys and epoxy on most non-metal handle materials. For metal handle materials like copper, brass or nickel I prefer pins.
A few words about using corbys...
Corbys can present some accuracy challenges if you don't have the right drill bits, but once you have the correct bits (counter-bores actually) corbys are easy, clean and secure.
A corby provides the vertical support that a pin provides and also provides a mechanical clamping force to hold the scales against the tang so that there's no need to rely on epoxy to keep the scales from lifting off the tang. For anyone that is not familiar with what a corby looks like, the copper "bolts" in the picture below are corbys.
Corbys can be used without epoxy entirely, or they can be used in addition to epoxy, in which case the epoxy is just there to seal the tang from water and air exposure. Epoxy can also help "lock" the corbys by sealing around them and their threads as well.
The special counter-bores that are made for corbys are very helpful. They leave a flat, square "shoulder" for the corby head to press on and they have a drill/guide built in to keep everything perfectly aligned over the guide/post hole. They are also made to fit corbys and are slightly "over" just enough to accommodate the swelling that occurs with many handle materials (such as G10 and micarta).
Here you can see the bit, the shoulder that the counter-bore leaves and the finished result.
Although I mostly use corbys myself, you could also use Loveless bolts in the same way. The Loveless bolts are not quite as clean looking because of the nut and thread size they use but they are stronger and have a very classic look and style.
Now a few words about using pins..
Pins can be used to clamp the scales against the tang as well, you just have to peen them.
This can be as simple as drilling a straight hole and hammering the ends of the pins until they flare a little (while being careful not to flare so much that you crack the handle material). Then you grind the pin ends smooth and don't remove more than you flared.
You can also "dome" the tops of the pins and leave them "proud" on the handle. Doming them is a great way to be able to use stag antler or elk antler scales without sanding the desirable texture smooth.
With some materials you'll want to use a tapered reamer on the ends of the hole and then peen the pin to fill the taper, with others a straight hole is best. With these methods pins will hold scales securely with or without epoxy just like corbys.
On this Mule I peened a titanium pin in the front and sanded it smooth. I used a corby in the rear of the handle.
I don't actually suggest peening titanium pins..it's a P.I.T.A., just use nickel pins and make your life easier. If you choose to use pins I suggest soft metals like brass, copper or nickel.
Once you've made nice round holes (warning..normal spiral-flute drill bits do not make round holes, talk to me if you need help on this) and you have a perfectly fit pin, you should be able to peen them so tight that the fit will be flawless no matter what material you are putting them in.
But, the reason I prefer using pins in metal materials instead of non-metal materials in because metals are more malleable and therefor more forgiving when it comes to forcing the pins to conform to the shape of the hole.
Here's an example of nickel pins carefully fitted and peened into a nickel bolster with carefully drilled and reamed holes. Once finished the pins have no gaps and disappear. Then the main body of the same handle is attached with copper corbys.
Either method (pins or corbys) can be done well and result in a high quality and great looking knife handle.
I've only used "knife rivets" to attach a handle one time and I'll never do it again. They were weak and cheap IMO. I personally think knife rivets are not a high quality option so I won't use them.
If anyone has questions about any of the little details regarding using corbys or pins let me know and I'll gladly help out if I can.
CK
Thank you brother. I'm just hoping that if I post pics of these things more people will see how easy it is and give it a go.Deadboxhero wrote: ↑Mon Apr 05, 2021 11:06 pmI never get tired of seeing your work Chad.
Perfection.
Thank you Sal.sal wrote: Very nice Chad. Thanx for sharing.
Using Micarta and G10 pins is a really good point that I forgot about, and I'm glad you mentioned it.
Thank you Tom.
Thank you Rusty.RustyIron wrote: That's some gorgeous work. Care to share how you create the scales out of the different materials, getting the boundaries really tight, and keeping everything symmetrical? I have no plans to make anything that extravagant, but it's good to have ideas for when projects arise.
Thank you for the added pictures. And no, the detailed explanations are not necessary. When I'm next inspired to do some scales, I might go for some straight lines, but much simpler than your work. That's within my skillset. Thanks for the inspiration to up my game and try something new. I guess I'll have to buy the next Mule.
Go for the MagnaCut!
Return to “Mule Team Discussion”
Users browsing this forum: No registered users and 1 guest
