How'd you wrap your mule handles with paracord? (pics welcome)
AlexRus
Re: How'd you wrap your mule handles with paracord? (pics welcome)
Postby AlexRus » Sun Jan 23, 2022 10:55 am
My Z-Wear Mule paracord-dressed
Araignee
Postby Araignee » Sun Jan 23, 2022 10:55 am
I had always wondered how the paracord wrappings were done, excellent thread :cheap-sunglasses
Thanks yablanowitz for the picture heavy tutorial 👌
Ramonade
Postby Ramonade » Mon Jan 24, 2022 2:53 pm
Pretty nice, that's dense ! does it have some girth width ?
:respect Owned :respect : S35VN, S45VN, S30V, S90V, S110V, Rex45, M4, SPY27, MagnaCut, 20CV, M390, K390, ZDP-189, Maxamet, CTS-BD1N, CTS-XHP, SRS13, CPM154, 154CM, LC200N, VG-10, D2, 12C27(+mod), 14C28N, 420HC, Nitrox, Victorinox's steel, 440C(and others), 8cr...., the end ?
Robin
. MNOSD member 004* aka Mr. N5s :face-clouds
AlexRus
Postby AlexRus » Mon Jan 24, 2022 2:58 pm
Yup, a little bit
Ramonade
Postby Ramonade » Mon Jan 24, 2022 4:10 pm
Yup, a little bit
Nice ! Seems comfortable. I might not do a ton of paracord wrapping in the future since I've equipped myself to do better scales than i did free hand, but it makes me want to try such a configuration.
Robin
yablanowitz
Postby yablanowitz » Tue Jan 25, 2022 8:58 pm
I'm glad you found it helpful. I've tried a bunch of different wraps, before and since, but this one gave me the best results for my use.
Ramonade
Postby Ramonade » Wed Jan 26, 2022 5:13 am
I have to say, I did some work on wood, in the kitchen and with cardboard already : The width this wrap gives is really nice for cuts that require some force.
Robin
yablanowitz
Postby yablanowitz » Thu Jan 27, 2022 11:23 pm
I've done a lot of hard cutting with Mules wrapped this way. Gives me plenty of traction, just enough padding and doesn't add too much bulk to bother me when I carry it across the small of my back. Careful, though. If you like it too much, you may never get around to finishing scales.
Ramonade
Postby Ramonade » Fri Jan 28, 2022 9:25 am
That's an issue I thought about only after a few days... might be too late!
Robin
hereiamu1
Postby hereiamu1 » Sat Jan 29, 2022 4:51 pm
cholla_remover
Postby cholla_remover » Sat Jan 29, 2022 5:12 pm
Nice thick wrap there. Looks twice as wide as other pics here, yet it doesn't appear that you double-wrapped it?
hereiamu1
Postby hereiamu1 » Sat Jan 29, 2022 8:37 pm
no double wrap, maybe the others have fewer cords inside?
cholla_remover
Postby cholla_remover » Sat Jan 29, 2022 10:38 pm
It looks good! I might try this with additional wraps of cord between the holes in the tang (as in your first photo) to see how girthy I can get it.
Ramonade
Postby Ramonade » Sun Jan 30, 2022 5:21 am
I do not know what you meant by fewer cords ? This wrap was pretty hard cause I had to cut the end of the cords inside to make them go through the 3/16 hole. Otherwise it would never have gone through !
Robin
archangel
Postby archangel » Sun Jan 30, 2022 6:39 am
If you feel you need more material, try double wrapping. You might remove the core on the first/inner layer, then use the standard PC for the outer layer. It works perfect for me. Just give it a go, you can always reverse it. You just need to use different holes for the start....
Michael
ZrowsN1s
Postby ZrowsN1s » Sun Feb 20, 2022 5:48 pm
A simple handle wrap and cardboard ducttape sheath.
"The world of edges has a small doorway in, but opens into a cavern that is both wide and deep." -sal "Ghost hunters scope the edge." -sal
AlexRus
Postby AlexRus » Wed Feb 23, 2022 12:36 am
Well done! 👍
ZrowsN1s
Postby ZrowsN1s » Wed Feb 23, 2022 12:44 am
Well done! 👍
Thanks!
Ramonade
Postby Ramonade » Wed Feb 23, 2022 6:19 am
Nice ! And the blue them is a nice touch (that sticker is a killer one)!
Robin
Return to “Mule Team Discussion”
Users browsing this forum: No registered users and 1 guest
