Having a shot at some timber scales
standy99
Post by standy99 »
Nothing too flash yet. Sanded a rough shape and drilled for a few Mosaic pins.
Most of the work was done on a disk sander and a drill. Made the scales a bit thinner after the below shots.
Re: Having a shot at some timber scales
Good looking timber. What kinda wood am I looking at here?
Xplorer
Post by Xplorer »
Lookin' good!
@ckc_knifemaker on Instagram.
standy99
Post by standy99 »
Bolster wrote:
Sun May 16, 2021 9:33 am
Amboyna/Rosewood wood- Stabilised KNIFE handle scales
Linked the seller in another timber scales thread
Bemo
Post by Bemo »
great start, I need to get a set going myself.
TomAiello
Post by TomAiello »
Looks good! I love those pins.
I'm tempted to suck up the shipping and buy some of those scales. You got them from George?
standy99
Post by standy99 »
TomAiello wrote:
Sun May 16, 2021 10:32 am
Yes George
Wait to you see them with a bit of oil on them. :D the rose really pops....
If you do order from George get some
“ Resifills - Epoxy resin cast KNIFE handle BLANKS and others - Sold singly × 1 “
Havnt worked out what’s going on in these but boy are they going to look good.
TomAiello
Post by TomAiello »
If you sand them to absurdly high grit, the stabilized and resin stuff comes out looking amazing. I used to stop at 1200 grit, and couldn't figure out how people made them shine. Then I sanded some up to 5000 grit, and the difference was incredible.
AlexRus
Post by AlexRus »
Subscribed. Watching :)
standy99
Post by standy99 »
Clamped.
Got a bit of epoxy everywhere :D :D
(Tip) Find baking paper stops getting clamps stuck to timber and sands off
RustyIron
Post by RustyIron »
It's fun seeing your progress.
Keep it comin'!
Thx.
I am guessing those pins are not peened?
TomAiello
Post by TomAiello »
standy99 wrote:
Mon May 17, 2021 11:24 am
Definitely. I bought a whole roll of parchment paper from Costco just for shop use.
standy99
Post by standy99 »
Bolster wrote:
Mon May 17, 2021 8:30 pm
No not mosaic pins.
Epoxy will keep them from moving, as there was a large amount of space in tang around pins and I scratch up pins with rough sandpaper so you get a bit of epoxy between pins and timber
The way a mule tang is leaves a great bond for epoxy with all the holes. I fill all of them up with epoxy and not just a coat on each side of the scales.
Coat scale - place on blade - fill holes and coat scale and clamp. Epoxy is cheap and the more the merrier in my book. :D
TomAiello
Post by TomAiello »
I've taken to using corby bolts in addition to mosaic pins, when I use mosaic pins. I have never had a problem with an epoxied mosaic pin moving at all--I'm just paranoid.
Here's a handle I put on a Brisa blank that way--with two corby bolts to hold things together around the mosaic pin.
AlexRus
Post by AlexRus »
TomAiello wrote:
Tue May 18, 2021 7:29 am
Looks good :)
FullScaler
Post by FullScaler »
I have been cleaning out my garage getting ready to move and dug up some very nice birds eye maple that I forgot I had. As soon as I saw it I thought of this thread and it wasn't long before I stopped cleaning the garage and started making some sawdust.
I was able to get them roughed out, drilled for pins, and epoxied before it got too late. I also roughed out some ironwood scales for another Mule so I was able to get two blades glued up tonight.
I used brass pins on both and am interested to see the contrast between the pins on the dark wood and the light maple. The corbies in the pics with the ironwood were just for holding the scales in place while I roughed them out a bit
Https://BladeProtection.com
WilliamMunny
Post by WilliamMunny »
FullScaler wrote:
Wed May 19, 2021 12:10 am
Did you have the wood stabilized first? I got the impression that it was fairly important to do.
Endura AUS-8, Manix 2 S30V, Alcyone BD1N, PM2 Micarta Cruwear, Native 5 Maxamet (2nd), Para 3 Maxamet (2nd), Magnacut Mule, Z-Wear Mule, BBB 15V Manix 2, REC PM3 10V Satin, Dragonfly Salt 2, GB2 M4.
WilliamMunny
standy99 wrote:
Sun May 16, 2021 5:33 am
How thick did you make your scales? 1/4”, 3/8”, 1/2”?
TomAiello
Post by TomAiello »
Nice maple, full scaler. That's some good looking wood. :)
